3850 EOL
rthomas5
Community Member
I'm trying to determine if the 3850 24-S and 48-P are EOL.  I see that IOS ver XE 16.3.5b might be EOL but is the switch itself EOL?
18 Replies 18
brselzer
The 3850 is not EOL at this time. You can look at all EOL notices for the 3850 here:
https://www.cisco.com/c/en/us/products/switches/catalyst-3850-series-switches/eos-eol-notice-listing.html
Usually we will publish an EOL notice a couple years ahead of time to give you time to migrate to a supported platfrom before the actual EOL date. There is not even an EOL notice for the platform out yet. Just certain versions of software.
Hope that helps!
-Bradley Selzer
CCIE# 60833
mpellegrino12
Level 3
Level 3
Martin L
EOL already ! why, those are new switch model. how old are they ?
The switches are not EOL... Just the IOS XE vetsion you have installed. Just upgrade the IOS version and you're good to go
oh, i see, good to know, tx
3850 Series is not EOL.
To avoid any confusion over EOL dates please use below link to check
https://www.cisco.com/c/en/us/support/switches/index.html
Mark Elsen
 - For your specific device use this app :
                    https://cway.cisco.com/sncheck/
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
langcblt
Community Member
When is 3560CX EOL ?
            - If you have a device like that check with : https://cway.cisco.com/sncheck/
 M.
I checked it with the URL you provided, but it did not tell me information relating to EOS or EOL.  It just tells me the device is still under coverage.  I want to know when did Cisco began selling this product, and when its End of Sale or End of Life date are
 - Normally EOS and EOL info is there available too,  please post complete output of what you saw or provide device serial number.
 M.
see attached. It didn't provide any info relating to EOS or EOL
 -End of Sale and End of Support have status Not Announced , means you don't need to worry about that , check again next year , for instance.
 M.
