08-31-2011 03:10 AM - edited 03-07-2019 01:59 AM
Not sure if the following is an issue or if I am overlooking something.
I am deploying two 4510 with dual SUPs.
One is running IP base and has SSO, I want to run that on the second switch as well, for this you obviously need IP base.
I have activated and installed the IP base license that came with one of the SUP.here is the output:
hostnaME#license install bootflash:FOX1111GEC1_20100000232016104.lic
Installing licenses from "bootflash:FOX111GEC1_20100000232016104.lic"
Installing...Feature:ipbase...Successful:Supported
1/1 licenses were successfully installed
0/1 licenses were existing licenses
0/1 licenses were failed to install
As the output above shows ip base has been installed.
Yet I still do not have the redundancy mode sso command available, when I check the feature set on this switch it still says that IPBase is not enabled:
WW-SUN-HO-ASW01#show license feature
Note: Built-in evaluation license cannot be cleared
Feature Name Enforcement Evaluation Clear Allowed Enabled
entservices true true true false
ipbase true false true false
lanbase false false true true
internal_service true false true false
I cant remember the exact command but one of the show license commands show LAN Base; In Use and IP Base; Not in Use
I am suspecting that it might have to do with the fact that I am running the license only based on the PAK for one SUP? Can I force it to to use IP base?
Also note that the switch that does have IP base uses the exact same Image as the one that doesnt.
Solved! Go to Solution.
08-31-2011 04:41 AM
show license all
show license image level
You may have clear idea with the outputs, and compared with your 2 switches.
also pay atten to the license boot level.
08-31-2011 08:02 AM
looking at your output, you have he lanbase license enabled, not the ipbase license.
to enable the ipbase license enter the following configuration;
conf t
licence boot level ipbase
exit
wr mem
then reboot the switch, the IP base license should then be enabled.
Please rate the post if helpful
08-31-2011 04:41 AM
show license all
08-31-2011 08:02 AM
conf t
exit
wr mem
08-31-2011 09:45 PM
Thanks Derek,
reseating the SUP worked and forced to IP Base after the IP Base boot level was hard set
10-02-2013 10:18 AM
4500X, WS-X45-SUP7L-E, WS-X45-SUP7-E and the new SUP8 licenses used to be one license per chassis and the license was tied to the serial number of the chassis. Recently Cisco changed some policies on licensing with the latest software update and as of IOS XE 3.4.xSG and later the licenses are now Right to Use (RTU). This means you wont have to go through the painful PAK activation process and tie the PAK to the serial number of the chassis and then apply the license to the chassis etc. But you do have to be running the new IOS version for this to work.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/release/note/OL_27990-01.html
"Cisco IOS XE Software Release 3.4.2SG introduces the Permanent Right-to-Use (PRTU) license feature."
This is brand new so if anyone gets a chance to test it out please update us. Thanks!
