6500 auto reload/restart/reboot
dimensyssrl
Hi all.
We have this serius problem with our 6513: it auto reboots itself randomly, and at this moment we haven't find the cause.
In last year it has reloaded itself many times (ten or more), but it dowsn't write anything in logs (no crashinfo, no warning messages, nothing).
So, we have tried to replace power supply, but it's happened again.
So, we have tried to supply power from another source, but it's happened again.
Last time this weekend, in the night between saturday and sunday (4 am), with no messages again.
At that moment there is virtually no traffic on the LAN (it's an office and the night is closed).
Anyone has an idea or anyone has this problem?
I specify only that, because we have many modules, we use autosaving configuration in nvram:
set config mode text nvram
set config mode text auto-save enable
set config mode text auto-save interval 15
And last, from sh environment power we see that the power is compiant to our needs:
PS1 Capacity: 2331.00 Watts (55.50 Amps @42V)
PS2 Capacity: 0.00 Watt
PS Configuration : PS1 and PS2 in Redundant Configuration.
Total Power Available : 2331.00 Watts (55.50 Amps @42V)
Total Power Chassis Limit : 7560.00 Watts (180.00 Amps @42V)
Total Power Chassis Recommended : 7560.00 Watts (180.00 Amps @42V)
Total Power Available for Line Card Usage : 2264.64 Watts (53.92 Amps @42V)
Total Power Drawn From the System : 1381.38 Watts (32.89 Amps @42V)
Total Power Drawn by the Chassis : 66.36 Watts ( 1.58 Amps @42V)
Total Power Drawn by the modules : 1128.96 Watts (26.88 Amps @42V)
Total Inline Power Drawn From the System : 151.02 Watts ( 3.59 Amps @42V)
Total Power Reserved as localpool for modules: 34.86 Watts ( 0.83 Amps @42V)
Remaining Power in the System : 949.62 Watts (22.61 Amps @42V)
Configured Default Inline Power allocation per port: 7.00 Watts ( 0.17 Amps @42V)
Slot power Requirement/Usage :
Slot Model PowerRequested PowerAllocated CardStatus
Watts A @42V Watts A @42V
1 WS-X6K-SUP2-2GE 145.32 3.46 145.32 3.46 ok
2 (empty supervisor slot) 0.00 0.00 145.32 3.46 none
3 WS-X6416-GBIC 118.02 2.81 118.02 2.81 ok
4 WS-X6148-RJ-45 100.38 2.39 100.38 2.39 ok
5 WS-X6148-RJ-45 100.38 2.39 100.38 2.39 ok
6 WS-X6148-RJ-45 100.38 2.39 100.38 2.39 ok
7 WS-X6148-RJ-45 100.38 2.39 100.38 2.39 ok
11 WS-X6148-GE-45AF 111.30 2.65 111.30 2.65 ok
12 WS-X6148-GE-TX 103.74 2.47 103.74 2.47 ok
13 WS-X6148-GE-TX 103.74 2.47 103.74 2.47 ok
Slot Inline Power Requirement/Usage :
Slot Sub-Model Total Allocated Max H/W Supported Max H/W Supported
To Module (Watts) Per Module (Watts) Per Port (Watts)
11 WS-F6K-GE48-AF 151.016 850.08 15.400
thanks
6 Replies 6
mihanlin
I've never heard of a switch reloading without a crash or reason.
Can you configure set test diag complete on the switch for me
Also what does the show logg buff 1024 say?
Does the switch have redundant supervisors? If so, do they both go off?
Is the switch powered through a UPS or some sort, or from mains?
The same for me, from this point my problem to understand the source of the issue.
It's already configured...
cat6513 (enable) sh test diaglevel
Diagnostic mode at last bootup : complete
Diagnostic mode at next reset : complete
No, we have only one supervisor (MSFC2)
Yes, the switch is powered through an UPS; we have verified that power supply is good, from the same source are powered all server in data center, and only machine that suffer this problem is catalyst 6513...
From buffered log we can see only last 2 hours events, reboot is happened 2 days ago (during weekend).
Switch log to a syslog server, from it we can view nothing meaningful, in any case:
Dec 2 03:48:06 10.10.10.21 2006 Dec 02 03:53:08 MET +01:00 %SYS-5-AUTOSAVE:Autosaving system configuration to NVRAM
Dec 2 03:48:32 10.10.10.20 2006 Dec 02 03:53:34 MET +01:00 %SYS-5-AUTOSAVE:Autosaving system configuration to NVRAM
Dec 2 03:56:16 10.10.10.20 2006 Dec 02 04:01:19 MET +01:00 %CDP-4-DUPLEXMISMATCH:Full/half duplex mismatch detected on port
Dec 2 04:04:03 10.10.10.20 2006 Dec 02 04:09:06 MET +01:00 %SYS-5-AUTOSAVE:Autosaving system configuration to NVRAM
Dec 2 04:08:39 10.10.10.20 2006 Dec 02 04:13:38 MET +01:00 %ETHC-5-PORTTOSTP:Port 11/1 joined bridge port 11/1
Dec 2 04:08:39 10.10.10.20 2006 Dec 02 04:13:38 MET +01:00 %ETHC-5-PORTTOSTP:Port 11/3 joined bridge port 11/3
Dec 2 04:08:39 10.10.10.20 2006 Dec 02 04:13:38 MET +01:00 %ETHC-5-PORTTOSTP:Port 11/4 joined bridge port 11/4
Dec 2 04:08:39 10.10.10.20 2006 Dec 02 04:13:38 MET +01:00 %ETHC-5-PORTTOSTP:Port 12/17 joined bridge port 12/17
Dec 2 04:08:39 10.10.10.20 2006 Dec 02 04:13:38 MET +01:00 %ETHC-5-PORTTOSTP:Port 12/18 joined bridge port 12/18
and so on...
reboot is happened between 04:04:03 and 04:08:29
thanks
Daniele
can you share output of show version with us?
Here it is:
cat6513 (enable) sh ver
WARNING: This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and use.
Delivery of Cisco cryptographic products does not imply third-party authority
to import, export, distribute or use encryption. Importers, exporters,
distributors and users are responsible for compliance with U.S. and local
country laws. By using this product you agree to comply with applicable
laws and regulations. If you are unable to comply with U.S. and local laws,
return this product immediately.
WS-C6513 Software, Version NmpSW: 8.4(3)
Copyright (c) 1995-2005 by Cisco Systems
NMP S/W compiled on Apr 26 2005, 22:48:26
System Bootstrap Version: 7.1(1)
System Boot Image File is 'bootflash:cat6000-sup2k9.8-4-3.bin'
System Configuration register is 0x2122
Hardware Version: 1.0 Model: WS-C6513 Serial #: TSC0710004A
PS1 Module: WS-CAC-2500W Serial #: ART06500035
Mod Port Model Serial # Versions
1 2 WS-X6K-SUP2-2GE SAL0711ACLC Hw : 4.2
Fw : 7.1(1)
Fw1: 6.1(3)
Sw : 8.4(3)
Sw1: 8.4(3)
WS-F6K-PFC2 SAL06375YDQ Hw : 3.3
Sw :
Sw :
3 16 WS-X6416-GBIC SAL0713AV5E Hw : 2.4
Fw : 5.4(2)
Sw : 8.4(3)
4 48 WS-X6148-RJ-45 SAL0715BUD5 Hw : 1.2
Fw : 5.4(2)
Sw : 8.4(3)
5 48 WS-X6148-RJ-45 SAL0715BUFT Hw : 1.2
Fw : 5.4(2)
Sw : 8.4(3)
6 48 WS-X6148-RJ-45 SAL0715BVP6 Hw : 1.2
Fw : 5.4(2)
Sw : 8.4(3)
7 48 WS-X6148-RJ-45 SAL0710A13L Hw : 1.1
Fw : 5.4(2)
Sw : 8.4(3)
11 48 WS-X6148-GE-45AF SAL0908406X Hw : 1.1
Fw : 7.2(1)
Sw : 8.4(3)
WS-F6K-GE48-AF SAL08435C7U Hw : 1.2
Sw : 8.4(1121)
12 48 WS-X6148-GE-TX SAD08080265 Hw : 5.0
Fw : 7.2(1)
Sw : 8.4(3)
13 48 WS-X6148-GE-TX SAD073800X0 Hw : 4.0
Fw : 7.2(1)
Sw : 8.4(3)
15 1 WS-F6K-MSFC2 SAL0706CNMZ Hw : 2.5
Fw : 12.1(26)E4
Sw : 12.1(26)E4
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 131072K 82416K 48656K 31232K 29153K 2079K 512K 170K 342K
Uptime is 2 days, 9 hours, 46 minutes
khaderbasha
Power is one of the reasons for reboots not the only reason. You should be looking into other areas. Slim down the chasis, use minimum number of modules required to meet your business objectives and observ. Which NMS do you use ? What events are being generated before the reboot. Are they consistent ?
I understand fixing random reboot is one of the dauting tasks. Is your IOS upto date ? which version are you using ? Is firmware on all modules upto date ?
Khader
mfawehin
I know its been quite a few years since you posted this thread but did you ever figure out the cause of this problem as I experiencing exactly the same on one of my 6500's?
Even the outage time is the same and it has happened quite a few times over the past few weeks.
Please let me know if you found a cause and solution to this auto reboot issue.
Cheers,
Martha.
