7206 vxr not booting up
mialbert
I have an issue with a 7206vxr that is booting into setup mode because it cannot find a configuration.  The config register is set good at 2102 but it boots into setup mode on restart.  I can put a configuration on it and it will run fine from running-config.  the dir nvram: command shows a startup configuration and the dir bootflash:  reveals the ios file fine.  The dir slot0:  reveals nothing however.  It reads device not ready.  This is the case even through it has a pcmcia flash card in the slot.  It seems like it should have enough to boot up between the bootflash and nvram however.  Is there a missing piece here?  Should there be an ios or config on the pcmcia flash?  Either by necessity or good practice?
glen.grant
  Is there a correct boot statement in the config pointing to your image in flash?
