01-27-2007 03:54 PM - edited 03-05-2019 02:01 PM
I have cisco 871 router which after press on the "reset" button doesn't start at all. The all lights on the router are flashing after cold restart, also I can't even connect trough console.
Need your help with the issue.
Thank you.
01-28-2007 05:32 AM
On what buad rates you use ( I m saying because your router's baud settings are changed so thats why u r watching ascii codes)
when you connect and when u try to connect after reset router
ok let me explain you
When router first connect with Hyperterminal the default settings are following
1) Buad rate is 9600 ( by pressing Default setting button)
When you reset the router your router becomes on default setting which is stated above
So just try to change the buad rates from 9600 to maximum which is 1175000 or some thing like that your router will give you console
hope this may help you
01-28-2007 09:32 AM
Thank you so much.
Finally I managed to console into the router , now then I boot it the following message is appearing
No bootable image file: flash:/
Unable to open boot file.
Whait the most efficient way to load boot iso into router, xmodem?
Thank you
01-28-2007 09:44 AM
Thank you so much.
Thank you
01-29-2007 05:52 AM
You can do xmodem but it might take long time. Or you can even try for tftpdnld command and using its parameters you can even upgrade using the LAN cable if you have direct access to the router.
01-29-2007 07:46 AM
Finally I managed to tftpdnld and transfered the bin file. But still after restarting the router there is no boot image
List of filesystems currently registered:
flash[0]: (read-write)
What is the command should I execute in order to get this fixed
01-29-2007 09:01 AM
Thank you all
The issue has been resolved
Thanks again
01-30-2007 10:37 PM
I m happy that your problem has been resolved
but what u did after downloading the image from router ( because you said that router is still not getting boot file....)
01-31-2007 06:13 AM
when I did tftpdnld -u eventually resolved the boot problem.
The problem then become that the config is not saved either, which I resolved with config-reg parametrs
