871W and Radio Interface
Syed Faraz Ali
   I have configured Cisco 871W with Wifi and Lan ports for user access . LAN ports seems to be working fine however SSID is not being broadcasted , following is configuration of my 871W
version 12.4
no service pad
hostname CISCO-871-W
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
dot11 vlan-name MY-LAN vlan 2
dot11 ssid MY-WIRELESS
authentication open
guest-mode
ip source-route
ip dhcp pool LAN-CLIENTS
   network 192.168.3.0 255.255.255.0
   default-router 192.168.3.1
ip dhcp pool WIFI-CLIENTS
   network 192.168.4.0 255.255.255.0
   default-router 192.168.4.1
ip cef
no ipv6 cef
archive
log config
  hidekeys
bridge irb
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description **WAN INTERFACE**
ip address 10.0.0.1 255.255.255.0
duplex auto
speed auto
interface Dot11Radio0
no ip address
no ip route-cache cef
no ip route-cache
ssid MY-WIRELESS
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
ip address 192.168.3.1 255.255.255.0
interface BVI1
ip address 192.168.4.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
CISCO-871-W#show ip int br
Interface                  IP-Address      OK? Method Status                Protocol
BVI1                       192.168.4.1     YES manual down                  down
Dot11Radio0                unassigned      YES manual reset                 down
Dot11Radio0.1              unassigned      YES unset  reset                 down
FastEthernet0              unassigned      YES unset  up                    down
FastEthernet1              unassigned      YES unset  down                  down
FastEthernet2              unassigned      YES unset  up                    down
FastEthernet3              unassigned      YES unset  up                    down
FastEthernet4              10.0.0.1        YES manual up                    up
Vlan1                      192.168.3.1     YES manual up                    down
Gregory Snipes
Level 4
Level 4
Your BVI is configured incorrectly. You should not have an IP on VLAN 1 and you should use the "bridge-group 1" command on it. As it is the dot11radio0.1 interface is not connected to anything and as such is not coming up.
Gregory Snipes
Level 4
Level 4
Also if you wanted to keep your wireless clients on a different subnet then your wired clients. You could always create a second SVI, say vlan 2, and put the wired ports in that other vlan.
Now i did this configuration, but i am unable to get IP address from DHCP on LAN & WLAN, when i manually configure IP address on host's wired lan, it does not work. but when i manually configure IP address on host's wireless lan interface it works perfect. i want my hosts on LAN & WLAN should get ip address from DHCP.
hostname Cisco-871w
boot-start-marker
boot-end-marker
no aaa new-model
no dot11 syslog
authentication open
guest-mode
ip source-route
ip dhcp pool MY-CLIENTS
   import all
   network 172.16.142.0 255.255.255.0
   dns-server 172.16.0.202
   default-router 172.16.142.254
ip cef
ip domain name mynet.com
ip name-server 172.16.0.202
no ipv6 cef
archive
log config
  hidekeys
bridge irb
description " WAN INTERFACE "
ip address 172.19.29.142 255.255.255.252
ip tcp adjust-mss 1300
duplex auto
speed auto
ip address 172.16.142.254 255.255.255.0
no ip route-cache
ssid MY-WIRELESS
channel 2412
station-role root
antenna gain 0
bridge-group 1
interface Vlan1
no ip address
bridge-group 1
interface BVI1
no ip address
ip default-gateway 172.16.142.254
control-plane
Cisco-871w#sh ip int br
BVI1                            unassigned        YES manual up                      up
Dot11Radio0                172.16.142.254   YES manual up                      up
FastEthernet0              unassigned         YES unset  down                   down
FastEthernet1              unassigned         YES unset  up                       down
FastEthernet4              172.19.29.142     YES manual up                     down
Vlan1                          unassigned          YES manual up                     down
now i did this configuration and i am able to get ip from DHCP on both LAN & WLAN segment but with different subnet.
now i want my clients on LAN & WLAN must get ip address of same segment.
Current configuration : 5012 bytes
version 12.4
no service pad
service password-encryption
hostname BNC
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.142.1 172.16.142.10
ip dhcp excluded-address 172.16.142.254
ip dhcp excluded-address 172.16.241.1 172.16.241.10
ip dhcp pool b&c-department
   import all
!  lease 7
ip dhcp pool VLAN20
import all
network 172.16.241.0 255.255.255.0
default-router 172.16.241.1
lease 7
ip cef
no ipv6 cef
bridge irb
interface Loopback1
ip address 172.16.200.142 255.255.255.255
description " WAN LINK "
duplex auto
speed auto
no ip address
no encryption vlan 1 mode ciphers tkip
no encryption vlan 20 mode ciphers tkip
ssid GuestWLAN
vlan 20
authentication open
guest-mode
ssid InternalWLAN
vlan 1
authentication open
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2462
station-role root
no dot11 extension aironet
no cdp enable
no snmp trap link-status
bridge-group 1
interface Dot11Radio0.2
interface Dot11Radio0.20
description Guest wireless LAN - routed WLAN
encapsulation dot1Q 20
ip address 172.16.241.1 255.255.255.0
ip virtual-reassembly
interface Vlan1
description Internal Network
no ip address
bridge-group 1
interface BVI1
description Bridge to Internal Network
router rip
version 2
network 172.16.0.0
network 192.168.142.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.142.20
ip route 172.19.29.0 255.255.255.0 172.19.29.141
ip http server
ip dns server
snmp-server community r3g10n RO
snmp-server location B&C
control-plane
bridge 1 route ip
