877 DNS problems
A cisco noob here. At home I have a small test lab with a 877, this 877 is connectect with the fa0 to my service provider router. I want to configure a DNS server, but when I do I can ping to a DNS name from my 877 but nog from my client. I hope some of you cisco gurus can help me out?
Here is a sh run and screenshots of the ping commando. (ps. I did enter de commando ip domain lookup)
version 12.4
no service pad
hostname Geoffrey_Home
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.0.1 10.0.0.10
ip dhcp excluded-address 10.0.0.200 10.0.0.254
ip dhcp pool NETWORK_10.0.0.0
   network 10.0.0.0 255.255.255.0
   default-router 10.0.0.254
   dns-server 10.0.0.254
ip host router 10.0.0.254
ip host laptop 10.0.0.11
ip name-server 8.8.8.8
username geoffrey privilege 15 secret 5 $1$m2LO$kd/uNJ6UjvMqVtE4RkIpx0
archive
log config
  hidekeys
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0
switchport access vlan 50
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 10.0.0.254 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Vlan50
ip address 192.168.2.200 255.255.255.0
ip nat outside
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.2.254
ip dns server
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Vlan50 overload
access-list 101 permit ip 10.0.0.0 0.0.0.255 any
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
login local
transport preferred none
transport input ssh
transport output none
scheduler max-task-time 5000
end
Translation of the text after the ping request: Ping-request cant find host laptop. Check the name and try again.
24 Replies 24
As you can see from the screenshot I added, I'm pinging the DNS name "laptop" what is refer to in the DNS as (10.0.0.11 client A).
Hello Geoffrey
That because as stated previously the ip host command is locally significant to the router so it will be able to ping the client however this will not be propagated outside that router
Res
Paul
Kind Regards
Paul
Ahh ok.. sorry I didnt see that. Ok...  so it is not possible to make this work?
Hello Geoffrey
As far as I understand it No - unfortunately not without making the router an DNS server or the options stated previously
Res
Paul
Kind Regards
Paul
Ok.. I think I dont realy understand you... with this config i made the router a dns server isnt it?
Hello
No it's not its performing dns lookups on the IP address you are specifying with the ip dns server x.x.x.x
Please review this csc doc for actual dns server on cisco router
https://learningnetwork.cisco.com/servlet/JiveServlet/previewBody/6248-102-1-20340/DNS%20Configuration%20of%20Cisco%20Router%20as%20DNS%20Server.pdf
Res
Paul
Kind Regards
Paul
Thanks, and sorry for the late respons. But I did found this on google already but dont see which part I didn't use which I need to make it work....
Sorry for the lack of knowledge, as I said noob here!
Found it.... When I add this piece of DNS config:
ip host laptop.geoffrey.nl 10.0.0.11
ip host laptop1.geoffrey 10.0.0.11
ip host laptop2 10.0.0.11
ip host laptop2.x 10.0.0.11
ip host laptop2. 10.0.0.11
I get a error with the following command on my client 10.0.0.12:
ping laptop
ping router
ping laptop2
ping laptop2.
I get a good response with the folling command on my client 10.0.0.12:
ping laptop.geoffrey.nl
ping laptop1.geoffrey
ping laptop2.x
obviously you have to config a "text"dot"text" host name... but can someone tell my... Why???
apologies for the typos i have fat fingers on a very small android phone?
iam not that bad at spelling -honest!
Sent from Cisco Technical Support Android App
Kind Regards
Paul
hahaha recognizable
