877W-M Routing ADSL
Dennis Wieringa
i own a Cisco 877W-M and a adsl line from Tele2.
i got it running with the adsl interface.
so it authenticates, and gets an ip adres, but when i use "test connection" i get an error that the "Exit interface" doesnt goes to the internet, and says its an routing issue.
and to be honest, i dont know what to change to get it working.
i use the dns servers provided by the ISP, so that should work.
here's an screenshot of the error, and solution i get?
ive also tryed to use this forum post, but that also doesnt work.
https://supportforums.cisco.com/document/116711/static-routes-next-hop-exit-interface-or-ip-address
johnd2310
Level 8
Level 8
Do you have a static route to the Internet? Something like ip route 0.0.0.0 0.0.0.0 dialer 0
thanks
John
**Please rate posts you find helpful**
johnd2310
Level 8
Level 8
thanks
John
that was indeed the issue,
but im guessing there's something wrong with the routing from dhcp to Dailer0,
because when i ping from console i get a 100% response, but from the client i get 0%
but the wan links seems to be working now, so that's one routing problem solved :)
devils_advocate
Level 7
Level 7
As John has said, it sounds like the Router may not have a default route set.
