9300 switch reloaded with below error
farazchakkungal
Hi All,
9300 switch got rebooted and i can see below message . Could you please let me know what it means :
%PLATFORM-4-ELEMENT_WARNING: Switch 1 R0/0: smand: 1/RP/0: limited space - copy files out of flash: directory. flash: value 100% (1910 MB) exceeds warning level 70% (1337 MB).
*Aug 31 11:16:06.059: %PLATFORM-4-ELEMENT_WARNING: Switch 1 R0/0: smand: 2/RP/0: limited space - copy files out of flash: directory. flash: value 74% (1412 MB) exceeds warning level 70% (1337 MB).
5 Replies 5
Leo Laohoo
request platform software package clean switch all
Use the command above to remove un-used files.
Hi Leo,
Thank you for the suggestion. However the switch got reloaded by itself throwing the above error which seems strange.
I am looking for possible crash file at the time of reload . will keep you posted
balaji.bandi
check with the DIR space of the flash: have you loaded any other information ? once it rebooted is that space gets cleaned?
BB
cae_technology
flash??
Mohsin Alam
Your flash is full, you can check the same using show file system.
Clean out files that are no longer required.
## Make sure to mark post as helpful, If it resolved your issue. ##
