9410R quad sup 2XL
ibrahimbadr4669
Dears,
Kindly, we are planning to have 9410R chassis each one will have two SUPs. do this setup applicable and all SUP will join the VSS (SSO,RPR) as we found that "Cisco StackWise Virtual can be configured only on one supervisor module per chassis. You must not install two supervisor modules in each chassis used in the Cisco StackWise Virtual solution."
is there any document that discuss this setup ?
Thanks and BR;
balaji.bandi
As per i know it only 1 super module support as on 17.13.X
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9400/software/release/17-13/configuration_guide/ha/b_1713_ha_9400_cg/configuring_cisco_stackwise_virtual.html
But if you need Quad Sup requirement can look Cat 9600 Model, that support Quad Supervisors in SVL
BB
