A switch is connected to itself
vipinrajrc
Level 3
Level 3
Hi Experts,
Recently i have found that one of our clients switch is connected to itself. I understad this using "sh cdp neighbor" command. Is there any special use for this type of connection??? or someone unknowingly connected it?? Does it make any problem llike broadcast stoem..???
Vipin
Thanks and Regards, Vipin
8 Replies 8
garapoglou
Level 3
Level 3
What's exactly the output of sh cdp neighbor command?
Best regards,
Giorgos
Please see the following
SW#sh cdp neighb
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
SW         Fas 0/9           125           S I      WS-C3560- Fas 0/13
SW         Fas 0/13          125           S I      WS-C3560- Fas 0/9
"SW" is the switch name. Previously infrastructure was managed by some other company. So i am not sure this is for a purpose or not... Please suggest a suitable answer...
Vipin
You should unplug the cable which connects switchport Fa 0/9 to Fa 0/13 to avoid broadcast storms. Even if STP is enabled, there's no reason for that connection.
For the record, my guess would be someone didn't check the cable was already connected to the switch and plugged it in on the first switchport available.
Best regards,
Giorgos
Thanks for the reply.. we will remove that cable soon.
Vipin
You're welcome!
Thanks for rating.
Giorgos
fgasimzade
Level 4
Level 4
Yes, it can be cause of broadcast storms, you should unplug, I see no reason why it should connected to itself
  Someone has made a built in physical loop .  Spanning tree probably took care of the potential serious problem .  You can verify with the show spanning-tree blocked ports"  command and i'll will bet that one of those ports shows blocked. Definetly get rid of it .
Hi Glen
Yes, STP is blocking the that port.
Vipin
