ACL in interface vlan (WS-6500-E)
arturo.reyna
Level 2
Level 2
I applied two ACL (in-out)in my interface vlan in a 6506-E router to restrict some connections in my network; ACL are working fine but ACL counters don't show hits those match, only the deny line at the end shows counters increasing.
Is it the correct way to apply ACL in a interface vlan (layer 3) in a WS-6500-E?
Please, let me know your comments.
TIA.
Edison Ortiz
That's expected in the 6500 as packets are fast-switched, not process-switched.
HTH,
__
Edison.
dreardon
Have you tried the following command?
Switch#show tcam interface Vlan3 acl in ip
Thanks, I can see the information I need.
