Bookmark
Subscribe
990
ACL with time-range not working
DON BROWN
I want to block Internet access specifically ports 80 and 443 for a specific IP address during specific hours.
I was also trying to test the ACL by adding additional deny statements - possibly this is causing the issue - don't know.
Here is the relevant parts of the config
interface Vlan1
 ip address 10.1.2.254 255.255.255.0
 ip access-group SchoolHours in
 ip nat inside
 ip virtual-reassembly in
ip access-list extended SchoolHours
 deny   tcp host 10.1.2.65 eq www any time-range schoolHours
 deny   tcp host 10.1.2.65 eq 443 any time-range schoolHours
 deny   tcp host 10.1.2.83 eq www any
 deny   tcp host 10.1.2.84 eq www any
 deny   tcp host 10.1.2.84 eq 443 any
 deny   tcp host 10.1.2.83 eq 443 any
 permit ip any any
 periodic weekdays 8:00 to 15:30
My laptop has address 10.1.2.84 but I am still able to browse the internet
Do I need to set up inspection of tcp traffic before this will work ?
Any suggestion most welcomed
You specified the ports 80 and 443 as source-ports, but you have to specify them as destination ports to make them work. Its's the server that uses (listens on) these ports:
deny tcp host 10.1.2.65 any eq www time-range schoolHours
deny tcp host 10.1.2.65 any eq 443 time-range schoolHours
deny tcp host 10.1.2.83 any eq www
deny tcp host 10.1.2.84 any eq www
deny tcp host 10.1.2.84 any eq 443
deny tcp host 10.1.2.83 any eq 443
permit ip any any
