adding a VLAN to a trunk without the trunk going down
Tshi M
Level 5
Level 5
I am working on two 6509 and few 4848...I just added a VLAN to my VLAN database and would like to allow it on few trunks without them going down. Last time I did, the trunks went down.
royalblues
Level 10
Level 10
All you have to do is to add the following command
switchport trunk allowed vlan add
The trunk should not go down due to this
Note that if you leave out the "add" modifier you will remove all the currently configured VLANs from the trunk. This will almost certainly take the switch off the net and prevent you from communicating with it.
HTH, rate if it does
Narayan
5 Replies 5
Edison Ortiz
Adding a Vlan to a database shouldn't cause the trunks to go down unless you are doing manual pruning. Is that the case here ?
royalblues
Level 10
Level 10
Narayan
I should of mentioned that the trunks are part of etherchannel. Would that make a difference? I have for intstance 8 interfaces that are member of an etherchannel.
I dont think that etherchannel should make a difference and trunk should not go down
Narayan
No difference whatsoever, just use the range command so all ports take the changes at the same time.
