Adding IP routing address
rcowheraocat
Community Member
I am using a PIX ASA5500 network appliance. And I am using the ASDM software to configure it. My question should be simple to answer.
I have an "example" 192.168.0.1/24 255.255.255.0 I am out of IP address and I need to add more I would like to add 192.168.1.1/24 255.255.255.0 and 192.168.2.1/24 255.255.255.0.
Can someone please help with this it has to easy to do I just don't know how and this is my first router I have ever had to setup.
PS and I am worthless at the command line interface.
noroutes4u
Are you trying to add more address to use in your global nat or are you adding another interfaces to use those address?
jaipal
Community Member
It will be too complicated while on trouble shooting any issues, you can try a class B subnet to over come this issue.
evsrajatgupta
Level 3
Level 3
Hi rcowheraocat,
(please Rate)
you can use VLSM in this csae.
I below link will help you to understand VSLM
http://www.cisco.com/warp/public/701/3.html
And this link will help you in VLSM CIDR Subnet Calculator
http://www.vlsm-calc.net/
Rick Morris
Level 11
Level 11
change your netmask
To allow for 192.168.0.0 - 192.168.3.255 use 255.255.252.0
