Adding WS-X6408A-GBIC module in 6506
corecycle
Currently 6506 switch has modules (Sup2, WS-F6K-PFC2, WS-X6408A-GBIC and WS-F6K-MSFC2)
I will add WS-X6408A-GBIC module in 6506 cisco catalyst switch. Currently 6506 has Sup2 engine, WS-X6408A-GBIC module and MSFC. Current Sup2 engine CAT OS version is Sw : 7.5(1).
Do I need to upgrade the cisco CAT OS version as per software advisor requires or not necessary to upgrade the OS version.
amikat
To my knowledge you can add another WS-X6408A-GBIC module to your current configuration and it will run O.K. with your CatOS release. But there is Cisco Security Advisory regarding 7.5(1) CatOS version (please see the link beneath) and as such I would strongly recommend to upgrade:
http://www.cisco.com/en/US/products/products_security_advisory09186a00801747e9.shtml
Best regards,
Antonin
OS upgrade is required.
Also upgrade to the latest release, so that the latest will have fixes for most of the bugs.
Hope this helps
Cheers
Somu
Rate helpful posts
