AIR-AP2802E-G-K9 unable to join WLC 2504
I couldn't join Air 2802i to 2504 Controller please suggest me suitable  ios  for wlc2500
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.0.115.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 20.0
Build Type....................................... DATA + WPS
System Name...................................... WFP01
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.168.0.10
IPv6 Address..................................... ::
Last Reset....................................... Power on reset
System Up Time................................... 0 days 2 hrs 50 mins 5 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... US - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +39 C
External Temperature............................. +43 C
Fan Status....................................... 3200 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ 24:7E:12:30:1F:E0
Maximum number of APs supported.................. 75
System Nas-Id.................................... WFP01
WLC MIC Certificate Types........................ SHA1/SHA2
cisco AIR-AP2802I-E-K9 ARMv7 Processor rev 1 (v7l) with 1030580/712796K bytes of memory.
Processor board ID FDW2149B6RW
AP Running Image : 8.2.151.0
Primary Boot Image : 8.2.151.0
Backup Boot Image : 0.0.0.0
2 Gigabit Ethernet interfaces
2 802.11 Radios
Radio Driver version : 9.0.5.5-W8964
Radio FW version : 9.1.8.1
NSS FW version :
@leyakhath muhammed wrote:
How can I upgrade the image version on a WLC 2504 from 8.0.115.0 to AIR-CT2500-K9-8-5-135-0
Please read the Release Notes.  It is not possible for a direct upgrade from 8.0.X.X to 8.5.135.0.  You need to upgrade to the latest of 8.2.X.X before upgrading to 8.5.135.0.
johnd2310
Level 8
Level 8
The 2802E requires the controller to be running at least 8.2.111.0 You need to upgrade the code on your controller.
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-2800-series-access-points/datasheet-c78-736497.html
John
**Please rate posts you find helpful**
Leo Laohoo
1. WLC is running the wrong code. For 2800, the controller needs to run 8.2.111.0 at the minimum.
2. The WLC is configured with the wrong Regulatory Domain. The AP has "-E" which means Europe but the controller is configured for the US.
Please advice me
Thank You
