Amber LED Flashing - 3560x
Jeff Harned
Hello All,
I have to two 3560x switches setup in a LAN.  I am using port 24 (VLAN 1) on both switches using a crossover cable for
Admn control.  Port 24 on one shows shows a continouslyy flashing amber port status LED while the other connection to port 24 of the other
switch is green.  I am able though to communicate with both switches.   I did perform both show interface and show interfaces counter errors
commands on the switch but nothing was obvious indicating a issue.
Any help on why the one port is amber but I can still communicate with the switch?
Thanks.
Jeff
15 Replies 15
Hi Madhu,
Not clear on what you are asking here but I did a show vlan for both switches and both
switches state that VLAN 1 is active for port 24.
Thanks.
Jeff
