Application not working when Switch/router as Gateway
faamin011
In change network topology, we are going to assign PC's Gateway as Switch (3750X) IP Address rather than server IP Address. Currently we have configured all Sytems's Gateway is Internet Server IP Address which we are going to replace with Switch IP as Gateway.
See the result when I have Server as Gateway
C:\Users\fahadamin>ping www.teamviewer.com
Pinging www.teamviewer.com [46.163.100.220] with 32 bytes of data:
Reply from 46.163.100.220: bytes=32 time=190ms TTL=110
Reply from 46.163.100.220: bytes=32 time=188ms TTL=110
Ping statistics for 46.163.100.220:
    Packets: Sent = 2, Received = 2, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 188ms, Maximum = 190ms, Average = 189ms
See when I change Switch/router IP as gateway
Request timed out.
Request timed out.
    Packets: Sent = 2, Received = 0, Lost = 2 (100% loss),
Issue is while connecting specific application like team viewer in which application tried to send keepalive message to the live server and in case of switch/router IP as gateway. Connection doesn't established. However it is working fine when Internet Server IP treated as gateway.
Please advice, no ACL or blockage implemented on Switch
33 Replies 33
Hi Fahad,
Try this one, ACL need to be changed as per your requierement. I need to add your users and managers IP addresses.
time-range Users
periodic weekdays 09:00 to 10:00
periodic weekdays 19:00 to 21:00
ip access-list extended Users
permit ip host 10.10.50.10 any time-range Users
permit ip host 10.10.50.20 any time-range Users
ip access-list extended Managers
permit ip host 10.10.50.30 any
permit ip host 10.10.50.40 any
route-map PBR permit 10
match ip address Users
set ip next-hop 10.10.10.59
route-map PBR permit 20
match ip address Managers
set ip next-hop 10.10.10.61
int vlan 1
ip add 10.10.50.1 255.255.0.0
ip policy route-map PBR
Hope it will help.
Best regards,
Abzal
Good approach but in presence of application firewal I don't think we need to configure timebase acl on router,this
work can better manage by TMG firewall and another main issue will be that we have to permit every host to both servers which we r"couldn't able to do with this approach. Also we can't rely host base acls specially in dhcp environment. Yes, subnets we can restrict or permit.
I have two main concerns only,
Every host should have both server access on network level, yes we apply permissions on application level.
Once I shifted both public networks to L3 then how traffic will route towards both.one default route will only route traffic to one service provider.
Pls advice, also tell me any other idea if u have to solve this delimea
Please respond
You can put servers on different VLAN and put hosts on those VLANs. Then just change PBR. If you want you can delete time-range.
Abzal
Best regards,
Abzal
