%ARP-3-INVAL_HDR
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-11-2012 10:02 PM - edited 03-07-2019 07:12 AM
we are getting these logs on Nexus 7010. How can we find the device that causing this problem?
2012 Jun 1 17:26:09
%ARP-3-INVAL_HDR
: arp [5793] Found incorrect hardware/protocol
type in ARP header: 6/2048
2012 Jun 1 17:28:00 last message repeated 2 times
2012 Jun 1 17:29:04 last message repeated 3 times
2012 Jun 1 17:40:08 last message repeated 1 time
2012 Jun 1 17:41:12 last message repeated 3 times
- Labels:
Other Switching
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-11-2012 11:51 PM
It seems that for this packet Hardware Type is wrong at 6 (it should be 1 for Ethernet), while Protocol Type 2048 is correct for IP.
You can span the inband port or enable ethanalyzer, and when this error happens, and stop the inband span or the ethanlayzer, and find the
source of the device.
N7K1# ethanalyzer local interface inband capture-filter "arp" write bootflash:arp.pcap (this will create a Wireshark file on bootflash which
you can tftp off of the switch and open it in Wireshark).
The time must match, meaning you need to stop the capture (Ctrl + C) as soon as you see the invalid ARP error message. You will need to open
second telnet session to switch to monitor show log for the error message.
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Ivan
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-11-2012 11:55 PM
I have done that. I am able to get 10 packets only.. can i limit for 10 mb for example..?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-12-2012 12:10 AM
I am checking like this:
NX1# ethanalyzer local interface inband capture-filter "arp" limit-captured-frames 1000 detail | i Hardware|Src
Capturing on inband
Ethernet II, Src: 00:50:56:9b:00:3f (00:50:56:9b:00:3f), Dst: ff:ff:ff:ff:ff:ff (ff:ff:ff:ff:ff:ff)
Hardware type: Ethernet (0x0001)
Hardware size: 6
Ethernet II, Src: 00:09:6b:58:46:f3 (00:09:6b:58:46:f3), Dst: ff:ff:ff:ff:ff:ff (ff:ff:ff:ff:ff:ff)
Hardware size: 6
Hardware size: 6
Hardware size: 6
Ethernet II, Src: 68:b5:99:72:6a:42 (68:b5:99:72:6a:42), Dst: 00:00:0c:07:ac:21 (00:00:0c:07:ac:21)
Hardware size: 6
Ethernet II, Src: 40:55:39:24:2d:42 (40:55:39:24:2d:42), Dst: 68:b5:99:72:6a:42 (68:b5:99:72:6a:42)
Hardware size: 6
Ethernet II, Src: 00:50:56:9b:00:34 (00:50:56:9b:00:34), Dst: ff:ff:ff:ff:ff:ff (ff:ff:ff:ff:ff:ff)
Hardware size: 6
Ethernet II, Src: 40:55:39:24:22:42 (40:55:39:24:22:42), Dst: 40:55:39:24:2d:42 (40:55:39:24:2d:42)
Hardware size: 6
But there is no anormal ARP, I think Nexus discards these packets and does not show with ethereal...
