ASA failover question
lkadlik
Level 4
Level 4
Is it possible to have an asa pair in active/standby mode where the WAN ip addesses are on different subnets?
I had always thought they needed to be on the same lan for it to work.
Sandeep Choudhary
Hi Ikadlik,
If you want to use failover as Active / Standby then It can not be possible on diff. Subnet because for that to work, The firewall have to have L2 Adjacency.
Please rate if it helps.
singhaam007
Level 9
Level 9
hello,
In ACTIVE/STANDBY mode, both IP Addresses MUST be in the same network address or you can use 2 units for this scenario. One unit primary and second one as backup.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807dac5f.shtml
But in juniper it is possible.
http://www.juniper.net/techpubs/software/junos-security/junos-security10.0/junos-security-swconfig-security/cc_deployment_scenarios.html
please rate if this helps.
thanks
Sandeep Choudhary
Hi Ikadlik,
