Astro Errors - CAT 4006 - Is this a possible SUP III module problem?
astanislaus
Level 2
Level 2
show log
Jan 6 14:53:32: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Astro 5-2(Fa
pagp Port channel information
5/9-16) - consecutive management requests timed out.how platform debug state
Jan 6 14:53:33: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Astro 2-5(Fa
policy-map Show QoS Policy Map
2/33-40) - consecutive management requests timed out. Switch Power
radi
Jan 6 14:53:35: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIM
4/41-48) - consecutive management requests timed out.
tacacs Shows tacac
Jan 6 14:53:41: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Astro 3-4(Fate Template information
ter
3/25-32) - consecutive management requests timed out.ers
Jan 6 15:00:46: %C4K_LINECARDMGMTPROTOCOL-4-INITIALTIMEOfigura
5/33-40) - consecutive management requests timed out.
vlan VTP VLAN status
Jan 6 15:03:32: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Astro 6-2(Fa
6/9-16) - consecutive management requests timed out.
bootflash: display information abo
Jan 6 15:03:32: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Astro 6-5(Fa
bootvar Boot and related environment variable
6/33-40) - consecutive management requests timed out.alendar Display the hardware calendar
Jan 6 15:03:32: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Asty information about ca
2/1-8) - consecutive management requests timed out.
flowcontrol
Jan 6 15:03:34: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Astro 5-6(Fa
5/41-48) - consecutive management requests timed out.
Jan 6 15:03:34: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Astro 6-1(Fa
6/1-8) - consecutive management requests timed out.
Jan 6 15:03:35: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Astro 5-2(Fa
Jan 6 15:03:35: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Astro 5-1(Fa
5/1-8) - consecutive management requests timed out.
Jan 6 15:03:35: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Astro 4-2(Fa
4/9-16) - consecutive management requests timed out.
Jan 6 15:03:35: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Astro 2-5(Fa
Jan 6 15:03:37: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Astro 2-6(Fa
2/41-48) - consecutive management requests timed out.
Jan 6 15:03:37: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Astro 6-3(Fa
6/17-24) - consecutive management requests timed out.
Jan 6 15:03:43: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Astro 4-6(Fa
Jan 6 15:03:44: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Astro 3-4(Fa
sourabhagarwal
Level 4
Level 4
%C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING (x16):
Explanation: There are persistent communication problems with the module ASIC
that fans out a single gigabit port to front-panel ports.
Recommended Action: Reinsert the module.
hope it helps ... rate if it does ...
glen.grant
Try powering the switch all the way down . Earlier versions of this switch had sdram problems sometimes asic timeout would occur , later versions of code actually had a built in test that runs in the background that tests this and if it see a problem it isolates the problem areas and reloads itself . If this happens it should be replaced anyway but the switch will continue to work until you get a replacement . This also could be caused by a faulty or infected station on the switch using up all the bandwidth causing the supervisor to be unable to talk to the linecards . You could try pulling one linecard at a time to eliminate that possibility or disable one module at a time from the command line just don't hang yourself out by disabling the card that feeds the uplink .
It appears that the problem has been resolved by replacing the SUP III module. Still on monitor.
