HIgh X-mit errors
viled
Community Member
I am running 2980's and 2948's in hp blade cabinets. When snooping around I found that the ports have x-mit errors in the 200,000,000 range or higher. They are running 8.4(4) What could be causing this? Also 1 carrier sense error
sourabhagarwal
Level 9
Level 9
check for any speed/duplex mismatch at both ends. try to set speed/duplex to auto/auto at both ends and then check if errors are still increasing or not.
Thank you!
I thought I would have seen FCS and alignment errors if that were the case
Xmit-Err Description:
This is an indication that the
internal send (Tx) buffer is full.
Common Causes: A common
cause of Xmit-Err might be
traffic from a high bandwidth
link being switched to a lower
bandwidth link, or traffic from
multiple inbound links being
switched to a single outbound
link. For example, if a large
amount of bursty traffic comes
in on a gigabit interface and is
switched out to a 100Mbps
interface, this might cause
Xmit-Err to increment on the
100Mbps interface. This is
because the interfaces output
buffer is overwhelmed by the
excess traffic due to the speed
mismatch between the incoming
and outgoing bandwidth.
sd
i had a simalar issue and the cause turned out to be our tape backup jobs
