02-22-2011 11:57 PM - edited 03-06-2019 03:42 PM
How can i let a switchport in a switch shutdown if the trunk of that switch fails or goes down.
02-23-2011 12:39 AM
You can use Cisco EEM (embedded event manager). But you will need to do some TCL scripting for your exact needs.
You can find example scripts here:
http://www.cisco.com/go/ciscobeyond/
And a lot more information on EEM here:
http://www.cisco.com/en/US/docs/ios/12_4t/netmgmt/configuration/guide/t_eemt.html
My scripting skills are non-existent so I don't know how hard this might be.
Also you need to check the IOS you have installed supports EEM. You might need an upgrade.
Ian
02-23-2011 12:49 AM
hi,
I think one possible way could be a Macro called "smartport macro"
But I don't know if you can bind this to the event "trunkport fails"
Rgds Martin
02-24-2011 05:49 AM
Thank you for your reply,
How can i bind smartport macro to an event.
