bandwidth adjustment
agentlife
Community Member
Given that there is a network connected to the inet via ADSL. Can i set the bandwidth to be greater for some specific IP's and smaller for others? If yes, how?
5 Replies 5
kamal-learn
Level 7
Level 7
hi
yes you can do using QOS.have a look on some posts that have already discussed that.
please do rate if it does clarify
thanx. Do u know where to find a little help about QOS implementation? I mean some sort of tutorial or HOWTO or whatever?
check this URL if it gives you any clue.
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12113ea1/3550scg/swqos.htm
rate if it helps...
Yes it does. Although it is a little bit theoritic and i do no not have much time for reading (i must do it immediately) it will definitely help.
hi latos
here is a snapshot of waht you can do
1- classify your traffic using classes:
class-map match-all webtraffic
match access-group 101
class-map match-all oracle-traffic
match access-group 102
2-create your access-list that contains or constraint the traffics defined above HTTP for web ,port and transport for oracle-traffic that oracle use ...
access-list 101....
access-list 102....
3-create a policy map to give a bandwidth and a priority to your traffic using policy-map
policy-map outbound-policy
class webtraffic (the classes you ve created before)
bandwidth 25 percent
class oracle-traffic
bandwidth 50 percent
(dont go over 75 percent of the total bandwidth)
4- apply the policy to the outgoing interface
interface serial
service-policy output outbound-policy
