bandwith limiting with qos issue
Alexander Demin
Hello.
I have Cisco Cat 2960G (IOS 12.2(50)SE3, lanbase image). Trying to limit available bandwith on port for 250 Mbps. The actual speed does not raises higher than 200 Mbps. Any ideas with queue set ?
sw1#show running-config interface gigabitEthernet 0/1
interface GigabitEthernet0/1
switchport access vlan 3
switchport mode access
load-interval 60
srr-queue bandwidth shape 0 0 0 0
srr-queue bandwidth limit 25
mls qos trust cos
flowcontrol receive desired
no cdp enable
spanning-tree portfast
spanning-tree bpdufilter enable
end
sw1#sh mls qos interface gigabitEthernet 0/1
GigabitEthernet0/1
trust state: trust cos
trust mode: trust cos
trust enabled flag: ena
COS override: dis
default COS: 0
DSCP Mutation Map: Default DSCP Mutation Map
Trust device: none
qos mode: port-based
sw1#sh mls qos interface gigabitEthernet 0/1 queueing
GigabitEthernet0/1
Egress Priority Queue : disabled
Shaped queue weights (absolute) :  0 0 0 0
Shared queue weights  :  25 25 25 25
The port bandwidth limit : 25  (Operational Bandwidth:27.28)
The port is mapped to qset : 1
sw1#sh mls qos interface gigabitEthernet 0/1 buffers
GigabitEthernet0/1
The allocations between the queues are : 25 25 25 25
sw1#sh mls qos queue-set 1
Queueset: 1
Queue     :       1       2       3       4
buffers   :      25        25      25    25
threshold1: 100    3200    100  100
threshold2: 100    3200    100  100
reserved  :    50      100      50     50
maximum : 400    3200    400   400
sw1#sh mls qos interface gigabitEthernet 0/1 statistics | b cos: incoming
  cos: incoming
0 -  4 :  2051465609            0            0            0            0
  5 -  7 :           0            0            0
  cos: outgoing
0 -  4 :  1354630319            1            0            0            0
  5 -  7 :           0            0            0
  output queues enqueued:
queue: threshold1 threshold2 threshold3
queue 0:           2           0           0
queue 1:  1354636197       63323     2072422
queue 2:           0           0           0
queue 3:           0           0          51
  output queues dropped:
queue 0:            0            0            0
queue 1:    200569558            9          668
queue 2:            0            0            0
queue 3:            0            0            0
Policer: Inprofile:            0 OutofProfile:            0
Regards, Alex.
DAO21-RIPE
5 Replies 5
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
See "These values are not exact because the hardware adjusts the line rate in increments of six." from:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_50_se/configuration/guide/swqos.html#wp1253412
It's true, but:
GigabitEthernet0/1
So, port bandwidth is actually not limited to 250 mbps but is even higher - abt. 270 mbps.
While the connected client doesn't get more than 200 mbps.
I suppose this could be an issue with buffer and queue weights, as almost all clents traffic goes to second queue.
DAO21-RIPE
Disclaimer
Posting
Excellent!  I missed the stats actually provides what the actual bandwidth is limited to.
I also agree with your supposition problem might be related to buffer allocations and queue weights.
One of the stats that would indicate buffering might be a problem is:
queue 0:           2           0           0
queue 2:           0           0           0
queue 3:           0           0          51
As you've also noted, most of the traffic appears to be enqueued in queue 1.
Perhaps more important, look at the drops for that queue's threshold1.
queue 0:            0            0            0
queue 2:            0            0            0
queue 3:            0            0            0
If this is TCP traffic, a too high drop rate will keep the  traffic, on average, from using all the available bandwidth (much as is  often seen with rate-limiters).
Since you've noted bandwidth peaks about about 200 Mbps, does it do so routinely?  If so, the share of buffer allocations might be insufficient.  I see your threshold settings have already been adjusted much larger than the defaults.  I see you've also doubled the reserve buffer allocation for this queue but you might try further increasing both it and increasing the proportion of reserved buffer allocations too; perhaps as much as 40 to 50%.
Again, if this is mainly TCP traffic that continues to attempt to push beyond the available bandwidth, it will normally average less than the available bandwidth so when drops are detected it either falls back to slow start or congestion avoidance.  This is effect is often more noticeable with fewer flows as more flows aggregate often often better use all the available bandwidth.
If you're shaping to conform to a provider's rate-limiting, you might try to find what intervals they are measuring against and whether they allow any bursting.  Knowing this, you might "push" your bandwidth allowance up a little to increase the average utilization.  Do note, when doing this it's difficult to not bump into a provider's rate-limiting settings both because of the inaccuracy of a this type of shaping and further because, unlike a router's shaper, you're also unable to define Tc, Bc, Be.
PS:
Not knowing how your other switch ports are utilized, if this port is "special", and if queue-set 2 not being used, you might want to move this port to queue-set 2 so it's custom settings don't impact other ports.
PS:
So..
Now my queue-set 1 buffer memory allocation si 25 25 25 25.
You mean, I can try increase allocation for queue 2 at 40-50%? So overall allocation will look like: 16 52 16 16 ?
WBR, alex.
DAO21-RIPE
Disclaimer
Posting
Yes, that's the idea.  You'll need to be careful, though.  Taking too much buffer allocation from other queues might cause them to have excessive drops.  I.e. Make a small change and monitor.  For example, you might first try 20 40 20 20 or 25 40 20 15.
Since queue set impacts all ports using it, that's also why I suggest moving this port to queue-set 2 so other ports aren't changed too.  I believe Cisco's thinking about queue sets was one of them would be used for "normal" ports and the other for "special" ports, e.g. host ports vs. uplink ports.
Increasing buffer allocations for the queue with the high drops probably won't help much if the congestion is sustained.
