Basic QoS for RTP
John Zack
Community Member
Hi guys, our issue probably is very simple, we use sdi over fiber units (actually they come with ethernet channel and we use it), so we use ethernet channel for RTP video streaming, from fiber receiver it goes to our lan network, we would like to set highest priority for RTP protocol for all our switches, we use Small Business 220 Series. Or maybe video protocolshave high priority by default? Thank you!
Ganesh Hariharan
Have look on the below configuration example for more clarification and understanding..
http://www.cisco.com/c/en/us/td/docs/ios/solutions_docs/qos_solutions/QoSVoIP/QoSVoIP.html
Hope it Helps..
-GI
Dennis Mink
is this inconjunction with cucm?  in which case you can trust the DSCP values the phones use for RTP and signalling (SIP?SCCP) by setting up trust statements on your access ports
Please rate if this helps
Please remember to rate useful posts, by clicking on the stars below.
Ganesh Hariharan
Hope it Helps..
-GI
acually it solved our issue, thanks a lot!
