BGP peer lost
mediaworksnz
Level 2
Level 2
Hello, we have a WAN (private IP) telco circuit. I have noticed over the last few days that the BGP neighbor relationship between us and the Telco has been continuously going up and down for periods of about one hour.
Could this be due to heavy traffic on this link ? i.e. can heavy user traffic flood the link and cause our router to temporarily lose it's BGP peer relationship ?
If so, how can I prevent this ?
Thank you for any help.
3 Accepted Solutions
Reza Sharifi
Heavy traffic will not cause BGP peering to go down. The issue could be your router or the one you are peering with. Inspect your router for any recent changes and also talk to your provider and see if they have made any changes on their side.
Hello
Do you see any errors in the physical interface?
If this is a p2p peering suggest check the physical connection with your isp however if the peering is between logical interfaces (ie loopbacks) I would then also suggest to check your routing and see if  path between the peers is being
lost
res
paul
Kind Regards
Paul
Julio E. Moisa
You could execute: show ip bgp neighbor x.x.x.x, and it could show a reason of the last reset. Also a debug could be used once it is happening.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
7 Replies 7
Reza Sharifi
Any interesting information in the log.
My router's BGP peering just bounces like this for about 1 hour, then stable until the next time it occurs:
Apr 5 19:30:49: %BGP-5-NBR_RESET: Neighbor 192.168.2.57 reset (Peer closed the session)
Apr 5 19:30:49: %BGP-3-NOTIFICATION: received from neighbor 192.168.2.57 4/0 (hold time expired) 0 bytes
Apr 5 19:30:49: %BGP-5-ADJCHANGE: neighbor 192.168.2.57 Down Peer closed the session
Apr 5 19:30:49: %BGP_SESSION-5-ADJCHANGE: neighbor 192.168.2.57 IPv4 Unicast topology base removed from session Peer closed the session
Apr 5 19:31:01: %BGP-5-ADJCHANGE: neighbor 192.168.2.57 Up
Apr 5 19:32:31: %BGP-5-NBR_RESET: Neighbor 192.168.2.57 reset (Peer closed the session)
Apr 5 19:32:31: %BGP-3-NOTIFICATION: received from neighbor 192.168.2.57 4/0 (hold time expired) 0 bytes
Apr 5 19:32:31: %BGP-5-ADJCHANGE: neighbor 192.168.2.57 Down Peer closed the session
Apr 5 19:32:31: %BGP_SESSION-5-ADJCHANGE: neighbor 192.168.2.57 IPv4 Unicast topology base removed from session Peer closed the session
Hello
lost
res
paul
Kind Regards
Paul
Julio E. Moisa
Last reset 00:11:10, due to Peer closed the session
https://community.cisco.com/t5/routing/bgp-peer-closed-status/td-p/1879804
Thank you very much.
mediaworksnz
Level 2
Level 2
I looked in the logs of our router and it says:
'Last reset 1d12h, due to Peer closed the session of session 1'
Out of interest, the Telco just responded with:
'I have looked into the fault and it appears that there has been high utilization.'.
