C1000-16T-2G-Lの消費電力について (Power Consumption of the C1000-16T-2G-L)
nomura0428
C1000-16T-2G-LをAC100V環境下で使用した際の消費電力を知りたいです。
以下のサイトを参照しましたが、よく分かりません。
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-1000-series-switches/nb-06-cat1k-ser-switch-ds-cte-en.html?oid=otren019232#Specifications
<<English>>
I would like to know the power consumption of C1000-16T-2G-L when used in an AC100V environment.
I referred to the following site but cannot figure it out.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-1000-series-switches/nb-06-cat1k-ser-switch-ds-cte-en.html?oid =otren019232#Specifications
Yes, that are  the values without PoE
pieterh
table-2, column-3 (16-port)
AC100V instead of 110V makes no difference for power consumption(kVA) ,
but with a little higher current (A) (kVA = V*A/1000)
Electrical
Full PoE
Full PoE Ext. PS
Full PoE
Full PoE
Full PoE
Voltage (auto ranging)
110 to 220V AC in
110 to 220V AC in
110 to 220V AC in
110 to 220V AC in
Frequency
50 to 60 Hz
50 to 60 Hz
50 to 60 Hz
50 to 60 Hz
Current
0.23A to 0.28A
0.15A to 0.2A
0.35A to 0.37A
0.29A to 0.48A
0.45A to 0.94A
Power rating
(maximum consumption)
0.15 kVA
0.15 kVA
0.45 kVA
0.8 kVA
0.95 kVA
Hi pieterh,
Thank you for your quick reply.
C1000-16T-2G-L" does not have PoE, so I assume the following values.
Is my understanding correct?
 "Power rating(maximum consumption)" is "0.05kVA".
 "Power consumption(watts)" is "16.68W" at 100% traffic.
Best regards,
Hitoshi Nomura
VTV Japan, Inc.
  8-port models 16-port models 24-port models 48-port models
Electrical Data Data Ext.PS Data Data Ext. PS Data FE Data Data FE Data
Voltage
(auto ranging)
110 to 220V AC in 110 to 220V AC in 110 to 220V AC in 110 to 220V AC in
Frequency 50 to 60 Hz 50 to 60 Hz 50 to 60 Hz 50 to 60 Hz
Current 0.13A to 0.22A 0.16A to 0.26A 0.16A to 0.26A 0.19A to 0.31A 0.20A to 0.33A 0.12A to 0.34A 0.29A to 0.48A 0.24A to 0.69A
Power rating
0.04 kVA 0.017 kVA 0.05 kVA 0.05 kVA 0.06 kVA 0.02 kVA 0.09 kVA 0.035 kVA
Power consumption
(watts)
0% traffic 14.04 13.15 14.52 14.4 1G: 15.84 11.22 1G: 27.37 21.41
- - - - 10G: 18 - 10G: 29.4 -
10% traffic 14.06 13.76 16.44 16.44 1G: 22.08 12.83 1G: 41.57 23.02
- - - - 10G: 24.48 - 10G: 42.28 -
100% traffic 14.26 14 16.68 16.68 1G: 22.8 17.15 1G: 53.66 23.03
- - - - 10G: 25.68 - 10G: 54.73 -
Weighted average 14.12 13.64 15.88 15.84 1G: 20.2 13.73 1G: 40.87 22.49
- - - - 10G: 22.7 - 10G: 42.1 -
