C2960X in L3 mode doesn't log ACL deny packets.
dtango2010
I'm using stack of two C2960X in L3 mode:
ZZZ-L3#sh sdm prefer
The current template is "lanbase-routing" template.
I have two Vlans and I need to block traffic between them. The problem is the second vlan is located on the other switch.
So Here is my setup:
LAN (VLAN1)--[ZZZ-L3]--trunk port--[YYY-L2]-- Vlan10
ip routing
no ip cef optimize neighbor resolution
interface Vlan1
ip address 192.168.1.2 255.255.255.0
no ip redirects
no ip proxy-arp
end
interface Vlan10
ip address 192.168.10.1 255.255.255.0
ip access-group 111 out
no ip redirects
no ip proxy-arp
end
ZZZ-L3#sh access-lists 111
Extended IP access list 111
10 permit tcp host 192.168.1.50 host 192.168.10.50 eq 4899
20 deny ip any any log
ZZZ-L33#sh ver
Switch Ports Model SW Version SW Image
1 28 WS-C2960X-24TS-L 15.2(2)E6 C2960X-UNIVERSALK9-M
* 2 28 WS-C2960X-24TS-L 15.2(2)E6 C2960X-UNIVERSALK9-M
I can confirm that ACL works:
RDP from 192.168.1.50 to 192.168.10.50 works OK.
And, If I ping 192.168.1.50 from 192.168.10.50 I receive "Request timed out."
However, I don't see any "%SEC-6-IPACCESSLOGDP: list 111 denied " in the log on the switch.
The other strange thing is that if I ping IP that doesn't exist in subnet 192.168.10.x - for example 192.168.10.60
First: I receive "Destination net ureachable" , but not a "Request timed out.".
Second: Deny log message shows up in the log:
%SEC-6-IPACCESSLOGDP: list 111 denied icmp 192.168.1.50 -> 192.168.10.60 (8/0), 1 packet
One more thing, If I define switch port in VLAN 10 on ZZZ-L3 and connect 192.168.10.50 directly to ZZZ-L3,
then  "%SEC-6-IPACCESSLOGDP: list 111 denied" is starting shows up int the log.
Any idea about such a strange behavior?
Thank you in advance,
Alex.
18 Replies 18
Julio,
Thank you for all your responses.
Unfortunately,  "ip access-list logging interval" didn't help as well.
As I mentioned to Paul above, I'm going to either create a ticket with TAC or simply close the topic.
I was able reproduce the same issue with the other stack I have.
So, probably L3 stack of 2xC2960X was not a best idea.
C2960X with lan-based IOS in L3 mode is not widely used (especially in stack), so may be this is why this was not reported before.
And yes, let's call this "a feature" :).
Thks,
Alex.
Thank you Alex, please keep us posted about the resolution.
Have a good day.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hello
Can you post - Show logging
res
Paul
Kind Regards
Paul
Paul,
Please check the post about ACL 115.
Thks,
AleX
