c2960x keeps rebooting
aabature001
Hello Team,
I don't know what the exact root cause might be, one of my access switches(c2960x v15.2(4)E8) keeps restarting nonstop. Error: ASIC/PHY POST failed. Cannot continue.  Please assist
See Switch full output below;
Loading "flash:/c2960x-universalk9-mz.152-4.E8/c2960x-universalk9-mz.152-4.E8.bi ................................................................................ .......................................................................Image pas
File "flash:/c2960x-universalk9-mz.152-4.E8/c2960x-universalk9-mz.152-4.E8.bin"
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(4)E8, R
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Fri 15-Mar-19 10:55 by prod_rel_team
Initializing flashfs...
Using driver version 4 for media type 1
mifs[7]: 12 files, 1 directories
mifs[7]: Total bytes : 1806336
mifs[7]: Bytes used : 834560
mifs[7]: Bytes available : 971776
mifs[7]: mifs fsck took 1 seconds.
mifs[7]: Initialization complete.
mifs[8]: 2 files, 1 directories
mifs[8]: Total bytes : 3870720
mifs[8]: Bytes used : 1213440
mifs[8]: Bytes available : 2657280
mifs[8]: mifs fsck took 0 seconds.
mifs[8]: Initialization complete.
mifs[9]: 5 files, 1 directories
mifs[9]: Total bytes : 258048
mifs[9]: Bytes used : 8192
mifs[9]: Bytes available : 249856
mifs[9]: mifs fsck took 1 seconds.
mifs[9]: Initialization complete.
mifs[10]: 5 files, 1 directories
mifs[10]: Total bytes : 258048
mifs[10]: Bytes used : 8192
mifs[10]: Bytes available : 249856
mifs[10]: mifs fsck took 0 seconds.
mifs[10]: Initialization complete.
mifs[11]: 780 files, 21 directories
mifs[11]: Total bytes : 122185728
mifs[11]: Bytes used : 54370304
mifs[11]: Bytes available : 67815424
mifs[11]: mifs fsck took 1 seconds.
mifs[11]: Initialization complete.
...done Initializing flashfs.
Checking for Bootloader upgrade..
Boot Loader upgrade not needed(v)
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled
POST: MA BIST : Begin
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: ACT2 Authentication : Begin
POST: ACT2 Authentication : End, Status Passed
extracting front_end/front_end_ucode_info (43 bytes)
Waiting for Stack Master Election...
POST: Thermal, Fan Tests : Begin
POST: Thermal, Fan Tests : End, Status Passed
POST: PortASIC Stack Port Loopback Tests : Begin
POST: PortASIC Stack Port Loopback Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: Failed PortPhyLoopback Packet Test asic_index 1 port_hardware_index 10
POST: Failed PortPhyLoopback Packet Test asic_index 1 port_hardware_index 9
POST: Failed PortPhyLoopback Packet Test asic_index 1 port_hardware_index 12
POST: Failed PortPhyLoopback Packet Test asic_index 1 port_hardware_index 11
POST: Failed PortPhyLoopback Packet Test asic_index 1 port_hardware_index 16
POST: Failed PortPhyLoopback Packet Test asic_index 1 port_hardware_index 15
POST: Failed PortPhyLoopback Packet Test asic_index 1 port_hardware_index 18
POST: Failed PortPhyLoopback Packet Test asic_index 1 port_hardware_index 17
POST: PortASIC Port Loopback Tests : End, Status Failed
%Software-forced reload
14:48:39 UTC Wed Jul 13 2022: Unexpected exception to CPUvector 2000, PC = 363D
-Traceback= 0x363D664z 0x308E544z 0x310AC6Cz 0x289D8FCz 0x289DAD8z 0x289DC50z 0x
Writing crashinfo to flash:/crashinfo_ext/crashinfo_ext_106
=== Flushing messages (14:48:44 UTC Wed Jul 13 2022) ===
Buffered messages:
Queued messages:
Jul 13 14:48:45.031: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console de
*Mar 1 00:00:50.733: Read env variable - LICENSE_BOOT_LEVEL =
*Jan 2 00:00:00.150: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module nam
Jul 13 14:48:05.090: in Switch 0. Cannot read pid from Flexstack module
Jul 13 14:48:24.566: %HARDWARE-3-MCU_I2C_READ_ERROR: I2C read failed in MCU and
Jul 13 14:48:24.629: %HARDWARE-3-MCU_I2C_BAD_DEV: I2C bad device address: 0 (alc
Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
SRR0 = 0x02ED7870 SRR1 = 0x00029200 SRR2 = 0x0363D664 SRR3 = 0x00029200
ESR = 0x00000000 DEAR = 0x1BB14F6B TSR = 0x84000000 DBSR = 0x01000000
CPU Register Context:
Vector = 0x00002000 PC = 0x0363D664 MSR = 0x00029200 CR = 0x39000093
LR = 0x0363D5FC CTR = 0x005CD9E4 XER = 0x8000001C
R0 = 0x0363D5FC R1 = 0x077F4BB0 R2 = 0x00000000 R3 = 0x0496FA18
R4 = 0x00000000 R5 = 0x00000000 R6 = 0x00000000 R7 = 0x00000025
R8 = 0x00000000 R9 = 0x04F70000 R10 = 0x04F70000 R11 = 0x00000000
R12 = 0x39000099 R13 = 0x1F183944 R14 = 0x005F7C88 R15 = 0x00000000
R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000
R24 = 0x00000000 R25 = 0x00000000 R26 = 0x00000001 R27 = 0x00000002
R28 = 0x04EB87E4 R29 = 0x00000000 R30 = 0x077F4BE8 R31 = 0x00000000
Stack trace:
PC = 0x0363D664, SP = 0x077F4BB0
Frame 00: SP = 0x077F4BC0 PC = 0x0363D5FC
Frame 01: SP = 0x077F4BE0 PC = 0x0308E544
Frame 02: SP = 0x077F4C40 PC = 0x0310AC6C
Frame 03: SP = 0x077F4C50 PC = 0x0289D8FC
Frame 04: SP = 0x077F4C70 PC = 0x0289DAD8
Frame 05: SP = 0x077F4C88 PC = 0x0289DC50
Frame 06: SP = 0x077F4CB8 PC = 0x005F7A74
Frame 07: SP = 0x077F4DB8 PC = 0x005F7CE4
Frame 08: SP = 0x077F4DC0 PC = 0x0363EC44
Frame 09: SP = 0x00000000 PC = 0x0363A940
Switch uptime is 1 minute, 35 seconds
cisco WS-C2960X-24PS-L (APM86XXX) processor (revision T0) with 524288K bytes of
Processor board ID FOC2414LCND
ÿ
CPU rev: B
Image passed digital signature verification
Board rev: 25
Testing DataBus...
Testing AddressBus...
Testing Memory from 0x00000000 to 0x1fffffff.../
Xmodem file system is available.
Base ethernet MAC Address: cc:7f:75:fa:2e:80
The password-recovery mechanism is enabled.
USB EHCI 1.00
USB EHCI 1.00
USB Console INIT
Initializing Flash...
mifs[5]: 12 files, 1 directories
mifs[5]: Total bytes : 1806336
mifs[5]: Bytes used : 834560
mifs[5]: Bytes available : 971776
mifs[5]: mifs fsck took 0 seconds.
mifs[6]: 2 files, 1 directories
mifs[6]: Total bytes : 3870720
mifs[6]: Bytes used : 1213440
mifs[6]: Bytes available : 2657280
mifs[6]: mifs fsck took 1 seconds.
mifs[7]: 5 files, 1 directories
mifs[7]: Total bytes : 258048
mifs[7]: Bytes used : 8192
mifs[7]: Bytes available : 249856
mifs[7]: mifs fsck took 0 seconds.
mifs[8]: 5 files, 1 directories
mifs[8]: Total bytes : 258048
mifs[8]: Bytes used : 8192
mifs[8]: Bytes available : 249856
mifs[8]: mifs fsck took 1 seconds.
mifs[9]: 781 files, 21 directories
mifs[9]: Total bytes : 122185728
mifs[9]: Bytes used : 54594560
mifs[9]: Bytes available : 67591168
mifs[9]: mifs fsck took 58 seconds.
...done Initializing Flash.
executing...
cisco Systems, Inc.
mifs[9]: mifs fsck took 0 seconds.
mifs[11]: 781 files, 21 directories
mifs[11]: Bytes used : 54594560
mifs[11]: Bytes available : 67591168
14:54:11 UTC Wed Jul 13 2022: Unexpected exception to CPUvector 2000, PC = 363D
Writing crashinfo to flash:/crashinfo_ext/crashinfo_ext_107
=== Flushing messages (14:54:16 UTC Wed Jul 13 2022) ===
Buffered messages:
Queued messages:
Jul 13 14:54:16.964: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console de
*Mar 1 00:00:50.939: Read env variable - LICENSE_BOOT_LEVEL =
*Jan 2 00:00:00.153: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module nam
Jul 13 14:53:37.090: in Switch 0. Cannot read pid from Flexstack module
Jul 13 14:53:55.605: %HARDWARE-3-MCU_I2C_READ_ERROR: I2C read failed in MCU and
Jul 13 14:53:56.531: %HARDWARE-3-MCU_I2C_BAD_DEV: I2C bad device address: 0 (alc
R0 = 0x0363D5FC R1 = 0x07AD6C80 R2 = 0x00000000 R3 = 0x0496FA18
R28 = 0x04EB87E4 R29 = 0x00000000 R30 = 0x07AD6CB8 R31 = 0x00000000
Stack trace:
PC = 0x0363D664, SP = 0x07AD6C80
Frame 00: SP = 0x07AD6C90 PC = 0x0363D5FC
Frame 01: SP = 0x07AD6CB0 PC = 0x0308E544
Frame 02: SP = 0x07AD6D10 PC = 0x0310AC6C
Frame 03: SP = 0x07AD6D20 PC = 0x0289D8FC
Frame 04: SP = 0x07AD6D40 PC = 0x0289DAD8
Frame 05: SP = 0x07AD6D58 PC = 0x0289DC50
Frame 06: SP = 0x07AD6D88 PC = 0x005F7A74
Frame 07: SP = 0x07AD6E88 PC = 0x005F7CE4
Frame 08: SP = 0x07AD6E90 PC = 0x0363EC44
ÿ
CPU rev: B
Board rev: 25
Testing DataBus...
2 Accepted Solutions
Leo Laohoo
Contact Cisco TAC and organize for an RMA.
The switch is dead.
If the working one failied, i agreed with @leo for RMA
BB
10 Replies 10
marce1000
           - FYI : https://bst.cisco.com/bugsearch/bug/CSCut90593
 M.
Jitendra Kumar
have checked with that?
Configuring Hardware Watchdog Reset
This feature is enabled by default. The following CLI command disables and re-enables this feature:
(config)# boot hardware-watchdog disable
(config)# no boot hardware-watchdog disable
This command requires a reboot to take effect.
The scheduler process-watchdog (software) remains in effect even after this feature is disabled.
Jitendra
Hi Jitendra,
The issue is that I can't even access the terminal as the switch keeps rebooting due to test failure.
Thank you
-Adam.
balaji.bandi
Are you trying to upgrade? or working one failed :
suggest getting another lower image, get on to ROMMON and re-image the device and test it.
BB
It's a working one(operational). Okay is it possible to download a lower image from cisco.
Thank you
-Adam.
yes, you can download it from the working one..
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/file_management/file_management/img_files.html
below tutorial also will guide you take the current firmware backup as well.
if you want to download current firmware from the working one and want to install on the crashing one.
i would suggest download current version from the working switch and install it and restore the config.
it seems some how firmware crashed.
https://youtu.be/P4lxfBlD6fA
Jitendra
BB
Leo Laohoo
The switch is dead.
Thanks for the feedback. So I won't bother reimaging
RachelGomez161999
Catalyst 2960x may reboot randomly and come up. This can happen when switch is a stack member or standalone. When part of stack as a member, entire stack does not go down when a member reloads, but everything connected to the 2960x that reloaded experiences an outage.
Rachel Gomez
