C2960X switchport mode trunk
dawnccier
Frequent Visitor
Frequent Visitor
Model: WS-C2960X-48LPS-L
OS version: 15.0(2a)EX5
VLAN: 10,20
Port configuration:
interface GigabitEthernet1/0/52
Query1. Is the vlan 10,20 frame can be switched via port52 when only 'switchport mode trunk' configured?
Query2. Is port52 trunk allowed vlan all when 'switchport mode trunk' configured?
Query3. Is the vlan 1 still the default vlan ?
2 Accepted Solutions
1. yes. you can limit VLANs using
#switchport trunk allowed vlan
command
2. yes default behavior is to allow all vlans
3. yes.
rate and mark this answer if this helps
Good luck
KB
Good luck
KB
rasmus.elmholt
Level 11
Level 11
A1: Per default all active VLANs are allowed on a trunk. As in your case
A2: See the previous answer
A3: VLAN 1 is still allowed and will be untagged pr. default.
Br,
Rasmus
Leo Laohoo
All VLANs found in the VLAN database will be allowed through because there is no limitation (default).
command
3. yes.
Good luck
KB
Good luck
KB
rasmus.elmholt
Level 11
Level 11
Br,
Rasmus
