C819 4G modem not recognized
Hi All,
Since a couple days I'm experiencing an issue with a C819-4G router.
The 4G connection unexpectedly disconnected, and I am unable to get it connected again.
There have been no configuration changes, and this config works fine in a spare router.
I found out that the Modem is not recognized any more.
router#sh cel 0 hardware
Modem Firmware Version =
Modem Firmware built =
Hardware Version =
International Mobile Subscriber Identity (IMSI) =
International Mobile Equipment Identity (IMEI) =
Integrated Circuit Card ID (ICCID) =
Mobile Subscriber Integrated Services
Digital Network-Number (MSISDN) =
Current Modem Temperature = 0 deg C
PRI SKU ID = , PRI version =
#sh controller cel 0
Interface Cellular0
4G WWAN Modem - Global Multimode LTE/DC-HSPA+/HSPA+/HSPA/UMTS/EDGE/GPRS
Cellular modem configuration
Modem is not recognized as valid
manufacture id:  0x00000000     product id: 0x00000000
Power status: Active
Then I saw the following in the controller output/logs:
router#sh controller cel 0 | beg SKU
SKU in LTE Family, Run DrMaxwell LTE Application
    Install Sierra Modem drivers
        GobiSerial
        GobiUSBNetMod
    Done.
    Bringing up USB modem, please wait...
        Waiting 1 Sec
        Waiting 2 Sec
        Waiting 3 Sec
        Waiting 4 Sec
        Waiting 5 Sec
        Waiting 6 Sec
        Waiting 7 Sec
        Waiting 8 Sec
        Waiting 9 Sec
        Waiting 10 Sec
        Waiting 11 Sec
        Waiting 12 Sec
        Waiting 13 Sec
        Waiting 14 Sec
        Waiting 15 Sec
        Waiting 16 Sec
        Waiting 17 Sec
        Waiting 18 Sec
        Waiting 19 Sec
        Waiting 20 Sec
        Waiting 21 Sec
        Waiting 22 Sec
        Waiting 23 Sec
        Waiting 24 Sec
        Waiting 25 Sec
        Waiting 26 Sec
        Waiting 27 Sec
        Waiting 28 Sec
        Waiting 29 Sec
        Waiting 30 Sec
        Waiting 31 Sec
    Modem bringup failed
    Configuring ICC driver, please wait...
insmod: cannot insert '/lib/modules/2.6.32/cwan_modems/c800_icc_dev.ko': unknown symbol in module
ifconfig: SIOCSIFADDR: No such device
route: SIOCADDRT: No such device
insmod: cannot insert '/lib/modules/2.6.32/cwan_modems/c800_virt_usb.ko': unknown symbol in module
    Done.
    Starting cwan_monitor application
Launched cwan_monitor process
    Done.
    Starting cwan_shim Application
    Done.
    Starting cwan_watch application
Launched CWAN SHIM Watch Process
Can not open /dev/cwan_cns_api[Thu Jan  1 00:01:40 1970]  Can not initialize IPC Library
    Done.
Can not open card_mgmt device
/ # [  774.983124] usb 1-1: new high speed USB device using fsl-ehci and address 2
[  775.119451] usb 1-1: New USB device found, idVendor=1199, idProduct=68a2
[  775.119481] usb 1-1: New USB device strings: Mfr=3, Product=2, SerialNumber=4
[  775.119504] usb 1-1: Product: MC7710
[  775.119519] usb 1-1: Manufacturer: Sierra Wireless, Incorporated
[  775.119539] usb 1-1: SerialNumber: 359470040052385
[  775.120223] usb 1-1: configuration #1 chosen from 1 choice
[  775.122673] GobiSerial 1-1:1.0: GobiSerial converter detected
[  775.124344] usb 1-1: GobiSerial converter now attached to ttyUSB0
In comparison this is the output on the spare router:
GobiSerial
GobiUSBNetMod
Done.
Modem Online, installing CWAN driver modules
cwan_modem modem_vid=0x1199 modem_pid=0x68a2
cwan_proc
cwan_userio
cwan_nfp
Done.
Done.
I'm beginning to think it's some kind of hardware issue or that the modem firmware is corrupted in some way, but I'm not sure.
​Has anyone else experienced a problem like this?
Kind regards,
Niels
6 Replies 6
Svante Bolander
Did you find the root cause for this? I am asking because I have run into the same problem with my 819.
Is there any other way to communicate with the modem and check status of it? AT commands?
Were you able to get to the root of this problem?
I am too getting this error on some of our routers and I am wondering if it's a hardware problem.
Thank you.
Probably hardware failure, we've replaced the router at the time. Since then it's running fine again.
Thank you Niels. That's what I am suspecting. I'm wondering if installing this modem will work:
https://www.cdw.com/shop/products/Sierra-Wireless-AirPrime-MC7355-wireless-cellular-modem-4G-LTE/3166983.aspx
The modem that my original 819s came with is a Sierra Wireless MC7750. The new ones we are buying are coming with the MC7350. The one above it's a MC7355, but it says it will work with Verizon LTE in US.
My routers are no longer supported anyway, so I don't lose anything although I will make sure I can return the modem in case it doesn't work.
What sucks is that I have 4 routers with the same symptom and I've always had high expectations from Cisco products.
Did it work? because I would like to use a 819 (Verizon version)  with modem: MC7354 compatible with Canada.
Thank for your answer :-)
Daniel G
Hello everybody, does anyone find a solution to this Modem Problem yet ?
