C9200-48P-E with module C9200-NM-4X no working -need help
pepeEL
Hi all. I am beginner in Cisco. I have a problem. I have switches C9200-48P-E in stack 4. In one switch i have module C9200-NM-4X. It is connected with other switch in stack cisco. But on this module C9200-NM-4X when run command show interface status it show me that port Te1/1/1 is unknown Te1/1/1 Swiatlo notconnect 1 full 10G unknown
. Why ? On other switch with which i want connect show me Te4/0/1 Swiatlo notconnect 1 full 10G SFP-10GBase-SR
Can anybody help me step by step how connect two stack switches by fibre. Please i am beginner. Thanks
31 Replies 31
Mark Elsen
 - Use compatible SFP(s) as mentioned in this list : https://tmgmatrix.cisco.com/?npid=1766
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
I use compatible CISCO SFP-10GBase-SR
balaji.bandi
what is the IOS XE code running on Both the switches.
is this SFP Module you looking to use is Cisco or any 3rd party ?
can you post show inventor working and not working
post complete output of show interface ten 1/1/1 and show interface ten1/1/1 trans
BB
On switch where SFP is reconized is ok i use version 15.0
On C9200-48P-E where in module C9200-NM-4X is show SFP as unknown i use version 16.12
On both switches i use the same gibic CISCO SFP-10GBase-SR
Inteface with ok reconized:
PD_xxxxxxxxxx_s-2#show interface tenGigabitEthernet 4/0/1
TenGigabitEthernet4/0/1 is down, line protocol is down (notconnect)
Hardware is Ten Gigabit Ethernet, address is 08d0.9f89.96b3 (bia 08d0.9f89.96b3)
Description: Swiatlo do PD_xxxxxxxxxxxx_Stak 3 Potry 1/1/1
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full-duplex, 10Gb/s, link type is auto, media type is SFP-10GBase-SR
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 9 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
PD_xxxxxxxx_s-2#
Inteface where is unknown
PD_xxxxxxxxxx_s-3#show interface tenGigabitEthernet 1/1/1
TenGigabitEthernet1/1/1 is down, line protocol is down (notconnect)
Hardware is Ten Gigabit Ethernet, address is 40f0.7806.8035 (bia 40f0.7806.8035)
Description: Swiatlo do PD_xxxxxxxxxx_Stak 2 Potry 4/0/1
Keepalive not set
Full-duplex, 10Gb/s, link type is auto, media type is unknown
input flow-control is on, output flow-control is unsupported
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: Class-based queueing
Output 0 broadcasts (0 multicasts)
0 output errors, 0 collisions, 3 interface resets
PD_xxxxxxxxx_s-3#
When try command: show interface tenGigabitEthernet 1/1/1 trans i get info:
Diagnostic Monitoring is not implemented.
                    >...Diagnostic Monitoring is not implemented.
 Probably a bug similar to https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuw98441 , use latest advisory software release on the 9200 and check if that can help : https://software.cisco.com/download/home/286320185/type/282046477/release/Bengaluru-17.6.4
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Upgrade code to 17.6.4 and test it.
BB
But how i can update software with save configuration of switches ? I have in stack 4 switches(devices). Sorry i am beginner and i need help step by step. Thanks. And which software i must update on my switches ? CAT9200 UNIVERSAL or CAT9200 UNIVERSAL - NO PAYLOAD ENCRYPTION ?
And realese Bengaluru is correct for me ? I am from Poland. How i can check what version no i have installed ?
pepeEL
Can you post show version.are you using bundle are install mode
bundle mode means you running switch stack with .bin file
if boot have packages.conf - means install mode
Look below upgrade guide  (in detailed)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9200/software/release/17-6/release_notes/ol-17-6-9200.html
BB
But how i can checkt it ?
If you closly look our reply you will find the answer post show version.are you using bundle are install mode
check #show boot
BB
PD_xxxxxxxxxxx_s-3#show version
Cisco IOS XE Software, Version 16.12.03a
Cisco IOS Software [Gibraltar], Catalyst L3 Switch Software (CAT9K_LITE_IOSXE), Version 16.12.3a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Tue 28-Apr-20 09:18 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2020 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 17.3.1r [FC3], RELEASE SOFTWARE (P)
PD_Narutowicza_s-3 uptime is 4 weeks, 6 days, 7 hours, 28 minutes
Uptime for this control processor is 4 weeks, 6 days, 7 hours, 30 minutes
System returned to ROM by Power Failure or Unknown at 10:51:59 UTC Fri Sep 30 2022
System restarted at 06:52:31 UTC Thu Dec 1 2022
System image file is "flash:packages.conf"
Last reload reason: Power Failure or Unknown
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-essentials Smart License network-essentials
dna-essentials Subscription Smart License dna-essentials
Smart Licensing Status: UNREGISTERED/EVAL EXPIRED
cisco C9200-48P (ARM64) processor with 649168K/3071K bytes of memory.
Processor board ID JAE24421JBV
2 Virtual Ethernet interfaces
312 Gigabit Ethernet interfaces
24 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
4060240K bytes of physical memory.
819200K bytes of Crash Files at crashinfo:.
819200K bytes of Crash Files at crashinfo-1:.
819200K bytes of Crash Files at crashinfo-2:.
819200K bytes of Crash Files at crashinfo-4:.
1941504K bytes of Flash at flash:.
1941504K bytes of Flash at flash-1:.
1941504K bytes of Flash at flash-2:.
1941504K bytes of Flash at flash-4:.
0K bytes of WebUI ODM Files at webui:.
Base Ethernet MAC Address : 40:f0:78:06:8b:00
Motherboard Assembly Number : 73-18791-04
Motherboard Serial Number : JAE24421JBV
Model Revision Number : C1
Motherboard Revision Number : B0
Model Number : C9200-48P
System Serial Number : JAE24421JBV
Switch Ports Model SW Version SW Image Mode
1 56 C9200-48P 16.12.3a CAT9K_LITE_IOSXE INSTALL
2 56 C9200-48P 16.12.3a CAT9K_LITE_IOSXE INSTALL
* 3 56 C9200-48P 16.12.3a CAT9K_LITE_IOSXE INSTALL
4 56 C9200-48P 16.12.3a CAT9K_LITE_IOSXE INSTALL
Switch 01
Switch uptime : 4 weeks, 6 days, 7 hours, 31 minutes
Base Ethernet MAC Address : 40:f0:78:06:80:00
Motherboard Serial Number : JAE24421G9Y
System Serial Number : JAE24421G9Y
Last reload reason : lost both active and standby
Switch 02
Base Ethernet MAC Address : dc:77:4c:a7:5a:80
Motherboard Serial Number : JAE24421GCW
System Serial Number : JAE24421GCW
Switch 04
Base Ethernet MAC Address : dc:77:4c:ea:d1:00
Motherboard Serial Number : JAE24421FFG
System Serial Number : JAE24421FFG
Last reload reason : Power Failure or Unknown
Configuration register is 0x102
PD_xxxxxxxxxx_s-3#show boot
Switch 3
Current Boot Variables:
BOOT variable does not exist
Boot Variables on next reload:
BOOT variable = flash:packages.conf;
Manual Boot = no
Enable Break = no
Boot Mode = DEVICE
iPXE Timeout = 0
As per the output it is install mode, so you can use archive install as mentioned in the document.
I want to bring another information for your notice, looks like Switch 3 as acting as master now.
if you like to make the stack stream line Sw1 to be master, Sw2 prospect master and other members, setup correctly with switch number and priority
show switch give you what switch has what number and priority.
BB
  • if you like to make the stack stream line Sw1 to be master, Sw2 prospect master and other members, setup correctly with switch number and priority
What you mean ? And can you tel me how change it to setup as master SW1 because in SW1 is installed module C9200-NM-4X and connect by sfp with other stack.
