01-04-2023 12:14 AM
Hi all. I am beginner in Cisco. I have a problem. I have switches C9200-48P-E in stack 4. In one switch i have module C9200-NM-4X. It is connected with other switch in stack cisco. But on this module C9200-NM-4X when run command show interface status it show me that port Te1/1/1 is unknown Te1/1/1 Swiatlo notconnect 1 full 10G unknown
. Why ? On other switch with which i want connect show me Te4/0/1 Swiatlo notconnect 1 full 10G SFP-10GBase-SR
Can anybody help me step by step how connect two stack switches by fibre. Please i am beginner. Thanks
01-11-2023 12:26 AM
post complete boot and also once its booted post show switch ( also post show run config here)
01-11-2023 12:33 AM - edited 01-11-2023 12:56 AM
show switch
Switch/Stack Mac Address : 40f0.7806.8b00 - Local Mac Address
Mac persistency wait time: Indefinite
H/W Current
Switch# Role Mac Address Priority Version State
1 Member 40f0.7806.8000 15 V01 Ready
2 Member dc77.4ca7.5a80 14 V01 Ready
*3 Active 40f0.7806.8b00 13 V01 Ready
4 Member dc77.4cea.d100 12 V01 Ready
PD_xxxxxxxxxxxxxxxxxxx_s-3#show running-config
Building configuration...
Current configuration : 51621 bytes
! Last configuration change at 08:32:21 UTC Wed Jan 11 2023 by xxxxxxxxxxxxxxxxxxxxxxxx
version 17.6
service password-encryption
service call-home
service unsupported-transceiver
platform punt-keepalive disable-kernel-core
hostname PD_xxxxxxxxxxxxxxxx_s-3
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
logging console emergencies
no aaa new-model
boot system switch all flash:packages.conf
switch 1 provision c9200-48p
switch 2 provision c9200-48p
switch 3 provision c9200-48p
switch 4 provision c9200-48p
login on-success log
table-map AutoQos-4.0-Trust-Cos-Table
default copy
table-map policed-dscp
map from 0 to 8
map from 10 to 8
map from 18 to 8
map from 24 to 8
map from 46 to 8
default copy
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
crypto pki trustpoint TP-self-signed-2701000198
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2701000198
revocation-check none
rsakeypair TP-self-signed-2701000198
crypto pki certificate chain SLA-TrustPoint
certificate ca 01
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
quit
crypto pki certificate chain TP-self-signed-2701000198
certificate self-signed 01
quit
crypto pki certificate pool
cabundle nvram:ios_core.p7b
license boot level network-essentials addon dna-essentials
diagnostic bootup level minimal
spanning-tree mode pvst
archive
path tftp://xxx.xxx.xxx.xxx
write-memory
memory free low-watermark processor 22870
no errdisable detect cause gbic-invalid
username xxxxxxxxxxx privilege 15 password 7 xxxxxxxxxxxxxxxxxxxxxxxxxx
username xxxxxxxxxxxx privilege 15 password 7 xxxxxxxxxxxxxxxxxxxxxxxxx
redundancy
mode sso
transceiver type all
monitoring
class-map match-any system-cpp-police-ewlc-control
description EWLC Control
class-map match-any AutoQos-4.0-Output-Multimedia-Conf-Queue
match dscp af41 af42 af43
match cos 4
class-map match-any system-cpp-police-topology-control
description Topology control
class-map match-any system-cpp-police-sw-forward
description Sw forwarding, L2 LVX data packets, LOGGING, Transit Traffic
class-map match-any AutoQos-4.0-Output-Bulk-Data-Queue
match dscp af11 af12 af13
match cos 1
class-map match-any system-cpp-default
description EWLC data, Inter FED Traffic
class-map match-any system-cpp-police-sys-data
description Openflow, Exception, EGR Exception, NFL Sampled Data, RPF Failed
class-map match-any AutoQos-4.0-Output-Priority-Queue
match dscp cs4 cs5 ef
match cos 5
class-map match-any system-cpp-police-punt-webauth
description Punt Webauth
class-map match-any AutoQos-4.0-Output-Multimedia-Strm-Queue
match dscp af31 af32 af33
class-map match-any system-cpp-police-l2lvx-control
description L2 LVX control packets
class-map match-any system-cpp-police-forus
description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
description MCAST END STATION
class-map match-any AutoQos-4.0-Voip-Data-CiscoPhone-Class
match cos 5
class-map match-any system-cpp-police-high-rate-app
description High Rate Applications
description MCAST Data
class-map match-any AutoQos-4.0-Voip-Signal-CiscoPhone-Class
match cos 3
class-map match-any system-cpp-police-l2-control
description L2 control
class-map match-all AUTOQOS_VOIP_DATA_CLASS
match ip dscp ef
class-map match-any system-cpp-police-dot1x-auth
description DOT1X Auth
class-map match-any system-cpp-police-data
description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-all AUTOQOS_DEFAULT_CLASS
match access-group name AUTOQOS-ACL-DEFAULT
class-map match-all AUTOQOS_VOIP_SIGNAL_CLASS
match ip dscp cs3
class-map match-any system-cpp-police-stackwise-virt-control
description Stackwise Virtual OOB
class-map match-any non-client-nrt-class
class-map match-any AutoQos-4.0-Default-Class
match access-group name AutoQos-4.0-Acl-Default
class-map match-any system-cpp-police-routing-control
description Routing control and Low Latency
class-map match-any system-cpp-police-protocol-snooping
description Protocol snooping
class-map match-any AutoQos-4.0-Output-Trans-Data-Queue
match dscp af21 af22 af23
match cos 2
class-map match-any system-cpp-police-dhcp-snooping
description DHCP snooping
class-map match-any system-cpp-police-ios-routing
description L2 control, Topology control, Routing control, Low Latency
class-map match-any system-cpp-police-system-critical
description System Critical and Gold Pkt
class-map match-any AutoQos-4.0-Output-Scavenger-Queue
match dscp cs1
class-map match-any system-cpp-police-ios-feature
description ICMPGEN,BROADCAST,ICMP,L2LVXCntrl,ProtoSnoop,PuntWebauth,MCASTData,Transit,DOT1XAuth,Swfwd,LOGGING,L2LVXData,ForusTraffic,ForusARP,McastEndStn,Openflow,Exception,EGRExcption,NflSampled,RpfFailed
class-map match-any AutoQos-4.0-Output-Control-Mgmt-Queue
match dscp cs2 cs3 cs6 cs7
match cos 3
policy-map AutoQos-4.0-Output-Policy
class AutoQos-4.0-Output-Priority-Queue
priority level 1 percent 30
class AutoQos-4.0-Output-Control-Mgmt-Queue
bandwidth remaining percent 10
queue-limit dscp cs2 percent 80
queue-limit dscp cs3 percent 90
queue-limit dscp cs6 percent 100
queue-limit dscp cs7 percent 100
queue-buffers ratio 10
class AutoQos-4.0-Output-Multimedia-Conf-Queue
class AutoQos-4.0-Output-Trans-Data-Queue
class AutoQos-4.0-Output-Bulk-Data-Queue
bandwidth remaining percent 4
class AutoQos-4.0-Output-Scavenger-Queue
class AutoQos-4.0-Output-Multimedia-Strm-Queue
class class-default
bandwidth remaining percent 25
queue-buffers ratio 25
policy-map AUTOQOS-SRND4-CISCOPHONE-POLICY
class AUTOQOS_VOIP_DATA_CLASS
set dscp ef
class AUTOQOS_VOIP_SIGNAL_CLASS
set dscp cs3
class AUTOQOS_DEFAULT_CLASS
set dscp default
policy-map AutoQos-4.0-Trust-Cos-Input-Policy
class class-default
set cos cos table AutoQos-4.0-Trust-Cos-Table
policy-map system-cpp-policy
policy-map AutoQos-4.0-CiscoPhone-Input-Policy
class AutoQos-4.0-Voip-Data-CiscoPhone-Class
set dscp ef
police cir 128000 bc 8000
conform-action transmit
exceed-action set-dscp-transmit dscp table policed-dscp
class AutoQos-4.0-Voip-Signal-CiscoPhone-Class
set dscp cs3
police cir 32000 bc 8000
class AutoQos-4.0-Default-Class
set dscp default
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
interface GigabitEthernet1/0/1
description
switchport access vlan 201
switchport mode access
spanning-tree portfast
spanning-tree bpduguard enable
interface GigabitEthernet1/0/2
description
interface GigabitEthernet1/0/3
description
interface GigabitEthernet1/0/4
description
interface GigabitEthernet1/0/5
description
interface GigabitEthernet1/0/6
description
interface GigabitEthernet1/0/7
description
interface GigabitEthernet1/0/8
description
interface GigabitEthernet1/0/9
description
interface GigabitEthernet1/0/10
description
interface GigabitEthernet1/0/11
description
interface GigabitEthernet1/0/12
description
interface GigabitEthernet1/0/13
description
interface GigabitEthernet1/0/14
description P1_1
switchport access vlan 15
interface GigabitEthernet1/0/15
description P1_3
interface GigabitEthernet1/0/16
description 1_11
switchport voice vlan 300
switchport port-security violation restrict
trust device cisco-phone
auto qos voip cisco-phone
service-policy input AutoQos-4.0-CiscoPhone-Input-Policy
service-policy output AutoQos-4.0-Output-Policy
interface GigabitEthernet1/0/17
description P1_7
switchport port-security maximum 2
interface GigabitEthernet1/0/18
description P1_8
interface GigabitEthernet1/0/19
description P1_10
service-policy input AUTOQOS-SRND4-CISCOPHONE-POLICY
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
description P1_12
interface GigabitEthernet1/0/22
description P1_22
interface GigabitEthernet1/0/23
description P2_7
interface GigabitEthernet1/0/24
description P2_12
interface GigabitEthernet1/0/25
description P2_13
interface GigabitEthernet1/0/26
description P2_1
interface GigabitEthernet1/0/27
description P2_6
interface GigabitEthernet1/0/28
description P2_9
interface GigabitEthernet1/0/29
description P2_11
interface GigabitEthernet1/0/30
description P2_23
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
description trunk tymczasowy Stak 1
switchport mode trunk
auto qos trust
macro description cisco-switch
spanning-tree link-type point-to-point
service-policy input AutoQos-4.0-Trust-Cos-Input-Policy
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
description
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
description Swiatlo do PD_xxxxxxxxxxxxxxxxx_Stak 2 Potry 4/0/1
auto qos trust
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface GigabitEthernet2/0/1
description P3_6
interface GigabitEthernet2/0/2
description P3_9
interface GigabitEthernet2/0/3
description P3_16
interface GigabitEthernet2/0/4
description P3_17
interface GigabitEthernet2/0/5
description P3_24
interface GigabitEthernet2/0/6
description P4_3
interface GigabitEthernet2/0/7
description P4_5
interface GigabitEthernet2/0/8
description P4_8
interface GigabitEthernet2/0/9
description P4_12
interface GigabitEthernet2/0/10
description P4_14
interface GigabitEthernet2/0/11
description P4_18
interface GigabitEthernet2/0/12
description P3_12
interface GigabitEthernet2/0/13
description P3_4
interface GigabitEthernet2/0/14
description P3_5
interface GigabitEthernet2/0/15
description P3_23
interface GigabitEthernet2/0/16
description P4_2
interface GigabitEthernet2/0/17
description P4_11
interface GigabitEthernet2/0/18
description P4_4 sala 4 cisco wideokonferencja
interface GigabitEthernet2/0/19
description P4_13
interface GigabitEthernet2/0/20
description P4_17
interface GigabitEthernet2/0/21
description P4_21
interface GigabitEthernet2/0/22
interface GigabitEthernet2/0/23
interface GigabitEthernet2/0/24
interface GigabitEthernet2/0/25
interface GigabitEthernet2/0/26
interface GigabitEthernet2/0/27
interface GigabitEthernet2/0/28
interface GigabitEthernet2/0/29
interface GigabitEthernet2/0/30
interface GigabitEthernet2/0/31
interface GigabitEthernet2/0/32
interface GigabitEthernet2/0/33
interface GigabitEthernet2/0/34
interface GigabitEthernet2/0/35
interface GigabitEthernet2/0/36
interface GigabitEthernet2/0/37
interface GigabitEthernet2/0/38
interface GigabitEthernet2/0/39
interface GigabitEthernet2/0/40
interface GigabitEthernet2/0/41
interface GigabitEthernet2/0/42
interface GigabitEthernet2/0/43
interface GigabitEthernet2/0/44
interface GigabitEthernet2/0/45
interface GigabitEthernet2/0/46
interface GigabitEthernet2/0/47
interface GigabitEthernet2/0/48
interface GigabitEthernet2/1/1
auto qos trust
interface GigabitEthernet2/1/2
interface GigabitEthernet2/1/3
interface GigabitEthernet2/1/4
interface TenGigabitEthernet2/1/1
interface TenGigabitEthernet2/1/2
interface TenGigabitEthernet2/1/3
interface TenGigabitEthernet2/1/4
interface GigabitEthernet3/0/1
switchport port-security aging time 2
switchport port-security aging type inactivity
macro description cisco-desktop
interface GigabitEthernet3/0/2
interface GigabitEthernet3/0/3
interface GigabitEthernet3/0/4
interface GigabitEthernet3/0/5
description P5_13
auto qos trust
interface GigabitEthernet3/0/6
description P6_5
interface GigabitEthernet3/0/7
description P6_7
interface GigabitEthernet3/0/8
auto qos trust
interface GigabitEthernet3/0/9
description P6_12
interface GigabitEthernet3/0/10
description P6_13
interface GigabitEthernet3/0/11
description P6_18
interface GigabitEthernet3/0/12
description P6_19
interface GigabitEthernet3/0/13
description P6_21
interface GigabitEthernet3/0/14
description P6_17
interface GigabitEthernet3/0/15
description P6_23
interface GigabitEthernet3/0/16
description P5_22
interface GigabitEthernet3/0/17
description P5_21
interface GigabitEthernet3/0/18
description P5_5
interface GigabitEthernet3/0/19
description P5_6 pok 101
interface GigabitEthernet3/0/20
description P5_8
interface GigabitEthernet3/0/21
description P5_3
interface GigabitEthernet3/0/22
description P5_9
interface GigabitEthernet3/0/23
description P5_10
interface GigabitEthernet3/0/24
description P5_14
interface GigabitEthernet3/0/25
description P6_22
interface GigabitEthernet3/0/26
description P6_24
interface GigabitEthernet3/0/27
description P6_12
interface GigabitEthernet3/0/28
description P6_13
interface GigabitEthernet3/0/29
interface GigabitEthernet3/0/30
interface GigabitEthernet3/0/31
interface GigabitEthernet3/0/32
interface GigabitEthernet3/0/33
interface GigabitEthernet3/0/34
interface GigabitEthernet3/0/35
interface GigabitEthernet3/0/36
interface GigabitEthernet3/0/37
interface GigabitEthernet3/0/38
interface GigabitEthernet3/0/39
interface GigabitEthernet3/0/40
interface GigabitEthernet3/0/41
interface GigabitEthernet3/0/42
interface GigabitEthernet3/0/43
interface GigabitEthernet3/0/44
interface GigabitEthernet3/0/45
interface GigabitEthernet3/0/46
interface GigabitEthernet3/0/47
interface GigabitEthernet3/0/48
interface GigabitEthernet3/1/1
interface GigabitEthernet3/1/2
interface GigabitEthernet3/1/3
interface GigabitEthernet3/1/4
interface TenGigabitEthernet3/1/1
interface TenGigabitEthernet3/1/2
interface TenGigabitEthernet3/1/3
interface TenGigabitEthernet3/1/4
interface GigabitEthernet4/0/1
description P7_3
interface GigabitEthernet4/0/2
description P7_4
interface GigabitEthernet4/0/3
description P7_5
interface GigabitEthernet4/0/4
description P7_6
interface GigabitEthernet4/0/5
description P7_8
interface GigabitEthernet4/0/6
description P7_10
interface GigabitEthernet4/0/7
description P7_14
switchport access vlan 300
interface GigabitEthernet4/0/8
description P7_12
interface GigabitEthernet4/0/9
interface GigabitEthernet4/0/10
description P7_23
interface GigabitEthernet4/0/11
description P7_24
interface GigabitEthernet4/0/12
description P8_8
interface GigabitEthernet4/0/13
description P8_10
interface GigabitEthernet4/0/14
description P8_11
interface GigabitEthernet4/0/15
description P8_13
interface GigabitEthernet4/0/16
description P8_14
interface GigabitEthernet4/0/17
description P8_15
interface GigabitEthernet4/0/18
description P8_16
interface GigabitEthernet4/0/19
description P8_19
interface GigabitEthernet4/0/20
description P8_21
interface GigabitEthernet4/0/21
description P8_22
interface GigabitEthernet4/0/22
description P7_1
interface GigabitEthernet4/0/23
description P7_7
interface GigabitEthernet4/0/24
description P7_8
interface GigabitEthernet4/0/25
description P7_15
interface GigabitEthernet4/0/26
description P7_19
interface GigabitEthernet4/0/27
description P7_21
power inline never
interface GigabitEthernet4/0/28
description P7_21
interface GigabitEthernet4/0/29
description P8_12
interface GigabitEthernet4/0/30
interface GigabitEthernet4/0/31
interface GigabitEthernet4/0/32
interface GigabitEthernet4/0/33
interface GigabitEthernet4/0/34
interface GigabitEthernet4/0/35
interface GigabitEthernet4/0/36
interface GigabitEthernet4/0/37
interface GigabitEthernet4/0/38
interface GigabitEthernet4/0/39
interface GigabitEthernet4/0/40
interface GigabitEthernet4/0/41
interface GigabitEthernet4/0/42
interface GigabitEthernet4/0/43
interface GigabitEthernet4/0/44
interface GigabitEthernet4/0/45
interface GigabitEthernet4/0/46
interface GigabitEthernet4/0/47
interface GigabitEthernet4/0/48
interface GigabitEthernet4/1/1
interface GigabitEthernet4/1/2
interface GigabitEthernet4/1/3
interface GigabitEthernet4/1/4
interface TenGigabitEthernet4/1/1
interface TenGigabitEthernet4/1/2
interface TenGigabitEthernet4/1/3
interface TenGigabitEthernet4/1/4
interface Vlan1
no ip address
interface Vlan201
ip address xxx.xxx.xxx.xxx 255.255.252.0
ip default-gateway xxx.xxx.xxx.xxx
ip forward-protocol nd
ip http server
ip http secure-server
ip access-list extended AutoQos-4.0-Acl-Default
10 permit ip any any
control-plane
service-policy input system-cpp-policy
line con 0
exec-timeout 0 0
logging synchronous
login local
stopbits 1
line aux 0
line vty 0 4
logging synchronous
login local
length 0
transport input ssh
line vty 5 15
logging synchronous
login local
transport input ssh
ntp server xxx.xxx.xxx.xxx
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
end
