C9200-48P-E with module C9200-NM-4X no working -need help
pepeEL
Hi all. I am beginner in Cisco. I have a problem. I have switches C9200-48P-E in stack 4. In one switch i have module C9200-NM-4X. It is connected with other switch in stack cisco. But on this module C9200-NM-4X when run command show interface status it show me that port Te1/1/1 is unknown Te1/1/1 Swiatlo notconnect 1 full 10G unknown
. Why ? On other switch with which i want connect show me Te4/0/1 Swiatlo notconnect 1 full 10G SFP-10GBase-SR
Can anybody help me step by step how connect two stack switches by fibre. Please i am beginner. Thanks
31 Replies 31
if i look your output :  * - means acting as master switch.
Switch Ports Model SW Version SW Image Mode
1 56 C9200-48P 16.12.3a CAT9K_LITE_IOSXE INSTALL
2 56 C9200-48P 16.12.3a CAT9K_LITE_IOSXE INSTALL
* 3 56 C9200-48P 16.12.3a CAT9K_LITE_IOSXE INSTALL
4 56 C9200-48P 16.12.3a CAT9K_LITE_IOSXE INSTALL
#show switch - command give you what switch has what number and priority.
BB
But how change which switch is a master ?
post the below output to look.
Note: if you have not configured the switch number and priority - when you reload or power off and on - whichever switch come first will become the master switch.
To fix that spend some time reading below guide : how you can order the switch numbers and priority :
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/white-paper-c11-741468.html
BB
PD_xxxxxxx_s-3#show switch
Switch/Stack Mac Address : 40f0.7806.8b00 - Local Mac Address
Mac persistency wait time: Indefinite
H/W Current
Switch# Role Mac Address Priority Version State
1 Member 40f0.7806.8000 1 V01 Ready
2 Member dc77.4ca7.5a80 1 V01 Ready
*3 Active 40f0.7806.8b00 1 V01 Ready
4 Member dc77.4cea.d100 1 V01 Ready
5 Member 0000.0000.0000 0 Provisioned
6 Member 0000.0000.0000 0 Provisioned
And i try copy from tftp soft to flash but i can not. I see on tftp that switch try copy but no transfer file and on switch i get this:
PD_xxxxxxx_s-3#copy tftp://10.0.1.7/cat9k_lite_iosxe.17.06.04.SPA.bin flash:
Destination filename [cat9k_lite_iosxe.17.06.04.SPA.bin]?
Accessing tftp://10.0.1.7/cat9k_lite_iosxe.17.06.04.SPA.bin...
%Error opening tftp://10.0.1.7/cat9k_lite_iosxe.17.06.04.SPA.bin (Timed out)
I also find on youtube manual about update firmware... It copy file from USB to flash and then only done it in
conf t
boot system flash:cat9k_lite_iosxe.17.06.04.SPA.bin
wr
reload
It is correct ? Because in manual which send me on forum show  STEP 3 and STEP 4 and it is other...?
https://www.youtube.com/watch?v=v1W46DypVNE
First step you need to correc this stack, before you go upgrade steps :
1. as i mentioned 3 switch is active and master, - spend some time read the document which was post before to correct switch numbers and switch priority.
2. in your config there may be some provision for switch 5 and 6 (which you dont have) so remove that config.
3. TFTP
are you able to ping TFTP IP address 10.0.1.7
for testing copy run to tftp server see if that copy the config file to tftp make sure TFTP working
make sure .bin file in the TFTP root folder. (you can google TFTP setup many documents can find)
yes you can also use USB to copy the File (use what ever comfortable)
BB
OK . sorry i read this document but i am beginner iand i dont understand how correct this switches in stack. Can you tell me please step by step.... If i understand i must change stack to SW1 will be MASTER not SW3 ? And question why i must correct this stack ?
I check on other Catalyst 2960S series also 4 switches in stack and i have this:
H/W Current
1 Member 6c50.4dac.b100 2 1 Ready
*2 Master b4a4.e3ea.3480 15 1 Ready
3 Member 6c50.4dc7.a980 3 1 Ready
4 Member 08d0.9f89.9680 1 1 Ready
How i can delete from config value for switch 5 and 6 ?
And if i have stack with 4 switches and i done update it update software on all 4 switches ?
- Are you sure is this same switch  - i see different MAC address of switch so you confusing the post again - Rather leraning here ?
in your recent output show switch - i see below priority changed to 15 on switch 2 ( that mean that is master)
STEP by STEP :
Any stack you like to order - this required downtime(required reboot) and port number will be changed so you need to make a note this before you doing any change, also check stack cables back side how they connected.
Example: “switch 1 renumber 2” renames switch 1 to 2 and changes the port numbers from G1/1/1 and Te1/1/1 to G2/1/1 and Te2/1/1. A reload is required for this to take effect.
So Look at the cables how they connected in your environment : (make necessary changes as below )
#switch 2 renumber 1
#switch 1 priority 15  ( example - so Switch 1 will be always master when you reboot or power of the device)
!Set priority 15 to elect switch in ACTIVE role
9300#switch <number> priority 14
!Set priority 14 to elect switch in STANDBY role
9300#switch <number> priority 13
!Set priority 13 to elect switch in next STANDBY role
9300#switch <number> priority 12
!Set priority 12 to elect switch in next STANDBY role
post show run output here.
YES if you read the document correctly and use the syntax we advised in the post and also release notes.
BB
But i can setup priority like as in Catalyst 2960 with use for MASTER 15 and for member use 1,2,3 ? Or i must use priority as you write 12,13,14 ?
stacking config nothing changed the way you doing cat 2960 same way
Master 15, next slave 14 , rest I don't care for completeness - good to use 13 and 12.
I suggest best practices 15...14...13...12
BB
ok i check and cabeles connected stack i have the same as you show on screen. ALso i change priority for switches. Now only i want delete config for 5 and 6 switches.
ok deleted config for switches 5 and 6. Now i am waiting when users in my bussines finished working, then i reload switch to read new configuration i try update this switches.
look i change priority but still switch 3 is as active-master. But i change priority to 15 for switch 1
PD_xxxxxxxxxxx_s-3#show switch
H/W Current
1 Member 40f0.7806.8000 15 V01 Ready
2 Member dc77.4ca7.5a80 14 V01 Ready
*3 Active 40f0.7806.8b00 13 V01 Ready
4 Member dc77.4cea.d100 12 V01 Ready
after changing have you write the config and reload ?
when you reload connect console to switch and catpure all the boot logs and post if you have still issue.
BB
Write ok because as you see change priority. Also reload.
Initializing Hardware...
System Bootstrap, Version 17.9.1r [FC8], RELEASE SOFTWARE (P)
Compiled Sat 07/23/2022 16:14:02 by rel
Current ROMMON image : Primary
C9200-48P platform with 4194304 Kbytes of main memory
boot: attempting to boot from [flash:packages.conf]
boot: reading file packages.conf
Waiting for 120 seconds for other switches to boot
Switch number is 4
All switches
