03-15-2020 08:10 AM
Hi Guys,
I am trying to configure Application Visibility for a Vlan interface on my C9200L. As soon as the desired VLAN is added in the CLI / Webui, the error message "NBAR Error: Can not enable Protocol-discovery general error" appears.
Any ideas? (The Ethernet ports can be added easily.)
LG,
PGI
03-15-2020 08:26 AM
Have you tried from the CLI via "ip nbar protocol-discovery" ? Ensure you have logging on to spot any error messages.
Cristian Matei.
03-25-2020 08:56 AM
03-27-2020 05:31 AM
What is the interface configuration on which you're trying to enable NBAR? Can you post it? Also do you see any output on NBAR commands, like "show ip nbar attribute"?
Cristian Matei.
03-15-2020 11:46 AM - edited 03-15-2020 11:47 AM
What is the version of Code running by the Cat 9200 ?
Look at the configuration guide and pre-requisites before enabling NBAR
03-25-2020 08:58 AM
03-25-2020 11:17 AM
configured it according to this "book". - is this means working still having issue.
if you having issue post more logs to understand.
