C9200 with NM-4X
dtran
Level 6
Level 6
Hello all,
I have a stack of C9200-24T with NM-4X modules. I have a couple 1G SFPs installed and in the running-config I can see G1/1/1 - G1/1/4 and T1/1/1 - T1/1/4 so I figure I could use G1/1/1-G1/1/4 since I have 1G SFPs. But then I run "show int status" I do not see G1/1/1-G1/1/4 I can only see T1/1/1-T1/1/4. And when I run "show int G1/1/1" I am not seeing the 1G SFP but I can see the 1G SFP when I run "show int T1/1/1"
So which interface should I use G1/1/1 or T1/1/1 ? I am confused ...
Thanks all for any inputs / suggestions !!!
Danny
Hi @dtran
 You shold use the T1/1/1.
If did not find for 9200, but 9300 we can se the information below that I believe explain your case.  As the module below is NM-4G, Cisco ask to Disregard the interfaces Ten but in your case as the module is NM-4X the Disregard should be for interface Gi1/1/x
Table 2. C9300-NM-4G Module
Interface Action
GigabitEthernet1/1/1
Configure this interface
GigabitEthernet1/1/2
GigabitEthernet1/1/3
GigabitEthernet1/1/4
TenGigabitEthernet1/1/1
Disregard
TenGigabitEthernet1/1/2
Disregard
TenGigabitEthernet1/1/3
Disregard
TenGigabitEthernet1/1/4
Disregard
Hi @dtran
Interface Action
Disregard
Disregard
Disregard
Disregard
Hello Flavio, hope you are doing well !!!
Thanks Flavio !!! I very much appreciate your help !!! the info you shared is extremely helpful !!
Thanks again !!!
Danny
