C9300-24S SFP compatibility
Marek H
I am planning to deploy a stack of two C9300-24S as a distribution switch. The in-house cabling is optical with LC connectors, but the WAN handoff will be RJ45. I was searching for a compatibility matrix to know what SFP modules to order for both copper and fiber connections. But I was unable to find one.
Are these compatible with C9300-24S?
-1 000BaseLX SFP - GLC-LH-SMD
- 1000BASE-T Copper SFP
GLC-SX-MMD, GLC-LH-MMD, GLC-TE and more supports this switch.
https://tmgmatrix.cisco.com/?npid=1821
Good luck
KB
Good luck
KB
given link is not working
balaji.bandi
yess both are compatable, Make sure (some OLD IOX XE code has bugs, see port up all time) latest code should have fixed that.
if you use uplink module on ten gig, worth using command speed 1000 (for 1G) also no auto negotiation if any issues.
BB
