C9300-NM-8X compatibility with SFP-10/25G-CSR-S
uppermost
Will below SFP
SFP-10/25G-CSR-S - 10/25GBASE-CSR SFP28
work with this module
C9300-NM-8X
This module has eight 10 GE slots with an SFP+ port in each slot. Each port supports a 1 GE or 10 GE connection.
Any combination of SFP and SFP+ modules are supported.
on 9300-24P switch when hardcoded to 10GB ?
8 Replies 8
M02@rt37
Hello @uppermost,
Here the SFP compatibles with C9300-NM-8X:
https://tmgmatrix.cisco.com/?npid=670
--SFP-10/25G-CSR-S not compatible
Best regards
Hi @uppermost
It is listed on the compatibility matrix. Which means it must be supported
https://tmgmatrix.cisco.com/?npf=76
Hello @Flavio Miranda
With C9300-NM-2Y yes it's ok! but with C9300-NM-8X it is not compatible.
Best regards
If these are not compatible today at the 10GB rate, will it be in the future with an IOS update or is it just electrically not possible with this module?
C9300-NM-8X and the SFP-10/25G-CSR-S
Hello @uppermost
not possible with this module! Even after upgrade!
You need  C9300-NM-2Y -- https://tmgmatrix.cisco.com/?npid=48
Best regards
balaji.bandi
No it work work with NM-8X module.
10G/25G SFP work with C9300-NM-2Y Module
BB
D-N
Anyone escalate this to support?
Anyone TEST this?
It's obvious why the TMGMatrix says "NO" - the module cannot work at 25gbps for obvious reasons. The question is is "will it work and be supported at 10gbps speeds"? It also stems from the fact that the newer optic is half price so may be a huge saving when you are working with large number of optic modules that make up a quarter of the budget.
it will not work
