C9300-NM-8X
D@mon123
HI
The interfaces does not seem to auto-negotiate to 1G although i have 1g sfp installed.
21 Replies 21
Mark Malone
what sfp is connected ? have you tried hardcode it if its a copper sfp or is it 1gb fiber sfp
supported sfps and required ios versions
C9300-NM-8X GLC-GE-100FX 100 Mbps SFP 2km Duplex Fiber MMF LC Optic 0 to 70C N IOS XE 16.5.1
SFP-10G-SR 10 Gbps SFP+ 300m (OM3) Duplex Fiber MMF LC Optic 0 to 70C Y IOS XE 16.5.1 IOS XE 16.5.1
SFP-10G-SR 10 Gbps SFP+ 400m (OM4) Duplex Fiber MMF LC Optic 0 to 70C Y IOS XE 16.5.1 IOS XE 16.5.1
SFP-10G-SR-S 10 Gbps SFP+ 300m (OM3) Duplex Fiber MMF LC Optic 0 to 70C Y IOS XE 16.5.1 IOS XE 16.5.1
SFP-10G-SR-S 10 Gbps SFP+ 400m (OM4) Duplex Fiber MMF LC Optic 0 to 70C Y IOS XE 16.5.1 IOS XE 16.5.1
SFP-10G-SR-X 10 Gbps SFP+ 300m (OM3) Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 16.10.1 IOS XE 16.10.1
SFP-10G-LRM 10 Gbps SFP+ 220m Duplex Fiber MMF LC Optic 0 to 70C Y IOS XE 16.5.1 IOS XE 16.5.1
SFP-10G-LRM 10 Gbps SFP+ 300m Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.5.1 IOS XE 16.5.1
SFP-10G-LR 10 Gbps SFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.5.1 IOS XE 16.5.1
SFP-10G-LR-S 10 Gbps SFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.5.1 IOS XE 16.5.1
SFP-10G-LR-X 10 Gbps SFP+ 10km Duplex Fiber SMF LC Optic -5 to 85C Y IOS XE 16.10.1 IOS XE 16.10.1
SFP-10G-ER 10 Gbps SFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.5.1 IOS XE 16.5.1
SFP-10G-ER-S 10 Gbps SFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.5.1 IOS XE 16.5.1
SFP-10G-ZR 10 Gbps SFP+ 80km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.5.1 IOS XE 16.5.1
SFP-10G-ZR-S 10 Gbps SFP+ 80km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.5.1 IOS XE 16.5.1
SFP-10G-BXD-I 10 Gbps SFP+ 10km Single-strand SMF LC Optic -40 to 85C Y IOS XE 16.5.1 IOS XE 16.5.1
SFP-10G-BXU-I 10 Gbps SFP+ 10km Single-strand SMF LC Optic -40 to 85C Y IOS XE 16.5.1 IOS XE 16.5.1
SFP-10G-BX40D-I 10 Gbps SFP+ 40km Single-strand SMF LC Optic -40 to 85C Y IOS XE 16.9.1 IOS XE 16.9.1
SFP-10G-BX40U-I 10 Gbps SFP+ 40km Single-strand SMF LC Optic -40 to 85C Y IOS XE 16.9.1 IOS XE 16.9.1
SFP-H10GB-CU1M 10 Gbps SFP+ 1m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.5.1
SFP-H10GB-CU3M 10 Gbps SFP+ 3m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.5.1
SFP-H10GB-CU5M 10 Gbps SFP+ 5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.5.1
SFP-H10GB-ACU7M 10 Gbps SFP+ 7m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.5.1
SFP-H10GB-ACU10M 10 Gbps SFP+ 10m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N IOS XE 16.5.1
SFP-10G-AOC1M 10 Gbps SFP+ 1m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.5.1
SFP-10G-AOC2M 10 Gbps SFP+ 2m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.5.1
SFP-10G-AOC3M 10 Gbps SFP+ 3m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.5.1
SFP-10G-AOC5M 10 Gbps SFP+ 5m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.5.1
SFP-10G-AOC7M 10 Gbps SFP+ 7m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.5.1
SFP-10G-AOC10M 10 Gbps SFP+ 10m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N IOS XE 16.5.1
FET-10G 10 Gbps SFP+ 100m Duplex Fiber MMF LC Optic 0 to 70C N IOS XE 16.5.1
DWDM-SFP10G-XX.XX 10 Gbps SFP+ 80km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.5.1 IOS XE 16.5.1
CWDM-SFP10G-XXXX 10 Gbps SFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.5.1 IOS XE 16.5.1
GLC-T
End Of Sale
10/100/1000 Mbps SFP 100m Cat5e/6A Copper RJ-45 Optic 0 to 70C N IOS XE 16.5.1
GLC-TE 10/100/1000 Mbps SFP 100m Cat5e/6A Copper RJ-45 Optic -5 to 85C N IOS XE 16.5.1
GLC-BX-D 1 Gbps SFP 10km Single-strand SMF LC Optic 0 to 70C Y IOS XE 16.5.1 IOS XE 16.5.1
GLC-BX-U 1 Gbps SFP 10km Single-strand SMF LC Optic 0 to 70C Y IOS XE 16.5.1 IOS XE 16.5.1
GLC-BX40-D-I 1 Gbps SFP 40km Single-strand SMF LC Optic -40 to 85C Y IOS XE 16.5.1 IOS XE 16.5.1
GLC-BX40-U-I 1 Gbps SFP 40km Single-strand SMF LC Optic -40 to 85C Y IOS XE 16.5.1 IOS XE 16.5.1
GLC-BX80-D-I 1 Gbps SFP 80km Single-strand SMF LC Optic -40 to 85C Y IOS XE 16.5.1 IOS XE 16.5.1
GLC-BX80-U-I 1 Gbps SFP 80km Single-strand SMF LC Optic -40 to 85C Y IOS XE 16.5.1 IOS XE 16.5.1
GLC-BX40-DA-I 1 Gbps SFP 40km Single-strand SMF LC Optic -40 to 85C Y IOS XE 16.5.1 IOS XE 16.5.1
GLC-EX-SMD 1 Gbps SFP 40km Duplex Fiber SMF LC Optic -5 to 85C Y IOS XE 16.5.1 IOS XE 16.5.1
SFP-GE-Z
End Of Sale
1 Gbps SFP 70km Duplex Fiber SMF LC Optic -5 to 85C Y IOS XE 16.5.1 IOS XE 16.5.1
SFP-GE-T
End Of Sale
GLC-SX-MM-RGD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -40 to 85C Y IOS XE 16.11.1 IOS XE 16.11.1
GLC-LX-SM-RGD 1 Gbps SFP 550m Duplex Fiber MMF LC Optic -40 to 85C Y IOS XE 16.11.1 IOS XE 16.11.1
GLC-LX-SM-RGD 1 Gbps SFP 10km Duplex Fiber SMF LC Optic -40 to 85C Y IOS XE 16.11.1 IOS XE 16.11.1
GLC-ZX-SM-RGD 1 Gbps SFP 70km Duplex Fiber SMF LC Optic -40 to 85C Y IOS XE 16.11.1 IOS XE 16.11.1
GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 16.5.1 IOS XE 16.5.1
GLC-LH-SMD 1 Gbps SFP 550m Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 16.5.1 IOS XE 16.5.1
GLC-LH-SMD 1 Gbps SFP 10km Duplex Fiber SMF LC Optic -5 to 85C Y IOS XE 16.5.1 IOS XE 16.5.1
GLC-ZX-SMD 1 Gbps SFP 70km Duplex Fiber SMF LC Optic -5 to 85C Y IOS XE 16.5.1 IOS XE 16.5.1
CWDM-SFP-XXXX 1 Gbps SFP 100km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.5.1 IOS XE 16.5.1
DWDM-SFP-XXXX 1 Gbps SFP 80km Duplex Fiber SMF LC Optic 0 to 70C Y IOS XE 16.5.1 IOS XE 16.5.1
hi mark,
my google search is failing me. i tried to look for compatible SFP/SFP+ for C9300-NM-8X.
where did you get this info? is this from cisco TMG matrix tool? link please?
Hi Dear,
Is GLC-LH-SMD supportable with C9300-NM-8X?
Yes, GLC-LH-SMD is supported.
Hi Mark,
Could you kindly confirm  the GLC-LH-SMD=  compatible with the iOS XE 17 version?
Yes it is.
****Kindly rate all useful posts*****
GLC-SX-MM
balaji.bandi
I will also check other end SFP ? what kind of SFP ? GLC-T - Fibre SFP  ?
can you post interface capabilities. (bot the side)
BB
Both the same
what version of ios are you running,can you post some outputs from the connected interface so we can see it ,
show interface x/x while its connected
show interface x/x transciever
alos what type of fibre are you using multi or single mode ?
TenGigabitEthernet1/1/2
Model: C9300-24P
Type: 1000BaseSX SFP
Speed: 1000
Duplex: full
Trunk encap. type: 802.1Q
Trunk mode: on,off,desirable,nonegotiate
Channel: yes
Broadcast suppression: percentage(0-100)
Unicast suppression: percentage(0-100)
Multicast suppression: percentage(0-100)
Flowcontrol: rx-(off,on,desired),tx-(none)
Fast Start: yes
QoS scheduling: rx-(not configurable on per port basis),
tx-(2p6q3t)
CoS rewrite: yes
ToS rewrite: yes
UDLD: yes
Inline power: no
SPAN: source/destination
PortSecure: yes
Dot1x: yes
GigabitEthernet1/0/25
Model: WS-C2960X-24PS-L
Speed: 1000
Duplex: full
Channel: yes
Fast Start: yes
tx-(4q3t) (3t: Two configurable values and one fixed.)
CoS rewrite: yes
ToS rewrite: yes
UDLD: yes
Inline power: no
PortSecure: yes
Dot1x: yes
GigabitEthernet1/0/26
Mulitmode.
If i use the same cable connection on another 3850 it works.
I can see my neighbor but cannot ping gateway etc.
