C9300 switch reset to factory
NetAdminMBC
So, got a brand-spankin' new Catalyst 9300.  Racked it up, connected to console port with PuTTY, booted the switch.  Went through the basic configuration script.  When it was done, I tried to enter enable mode and found I couldn't - evidently, I fat-fingered the password.
I don't care about the config that's on there now- it's easily re-creatable.  I'd like to erase the startup config and start over, but I can't seem to get there.  Is there a procedure document somewhere that will tell me?  I vaguely remember, with older switches, breaking into the power up routines and erasing the config from flash.  Is that still possible?
22 Replies 22
Hi NetAdminMBC,
Power cycle the switch. Immediatly press and hold the Mode button. Hold the button till the Status LED will go amber. Then on the console you should be in Boot Loader.
Switch:
Add the following variables to ignore the startup configuration.
Switch: SWITCH_IGNORE_STARTUP_CFG=1
Boot the switch.
Switch: boot
Once the switch has booted you can copy the saved config back into the running config.
Switch# copy start runn
Next set your password(s). Remove the variables we set in Boot Loader.
Switch# no system ignore startupconfig switch all
Save your new config.
Switch# copy runn start
In this way, you don't have to reconfigure the switch. The only password will reset.
Spooster IT Services Team
 Thanks to all.  I tried the "hold the mode button" process and it didn't work - switch booted as normal.
I cabled gig0/0 (the mgmt-vrf interface) to a laptop and telnetted for the hell of it  - through telnet, it took what I knew to be the enable password (when i had entered the enable password in a console session, it rejected it and I assume wanted the enable secret password).  I removed the enable secret and now i can elevate a telnet session with the enable password.
I did the process, but I never saw the ambar light.
I tried to press the butoon more than 1 minute.
Could you help, please?
I found a solution here: https://community.cisco.com/t5/switching/catalyst-9300-password-recovery/m-p/3675832/highlight/true#M445273
Pressing and holding the mode button does nothing for me, i have read other threads and the solution that has worked for me is after power cycling the switch just start pressing the mode button multiple times until you see "switch:"
Holding the Mode button doesn't work.  You need to just press and release during boot until switch: prompt shows up.
Yes, this is the correct way to interrupt the boot process on a catalyst  9300.
power on then keep pressing the bottom till you get switch : on ur screen
That might work for classic IOS but for 9300 that is not going to work.
  1. Do not touch the Mode button.
  2. Boot up the Catalyst 9300 and pay close attention to the console.  Once the line "Last reset cause: SoftwareReload" appears, press the Mode button 3 times.
Yes, it works for me. Thank you.
This stage of the config needs to be done from configuration mode
Switch(config)# no system ignore startupconfig switch all
I held down the mode button but that didn't work. What works is to press the mode button repeatedly.
Tunde Olubiyi
The above procedures to get to ROMMON will NOT work! Here is EXACTLY what to do to make it work:
1- Connect the power cord to your switch (don't press anything yet).
2- As soon as the "System LED blinks rapidly" press and release the Mode button 2-3 times. The switch enters the ROMMON  mode.
Voila - Simple!
