C9407 / Stackwise Virtual / Dual-Active Detection
patrick86
Frequent Visitor
Frequent Visitor
I have a question regarding the dual active link on a StackWise Virtual implementation (C9407R + C9400-SUP-1).
As far as I know, the SVL have to be between the Supervisor engines (10G or 40G Links).
For the dual active link, i did not find any Information. Only that it can be 10G or 1G.
Is it possible to implement the dual active Link on a copper Linecard  port?
Or is it neccessary to implement the dual active link on the Supervisor engine, too?
Kind regards,
Patrick
balaji.bandi
7 Replies 7
balaji.bandi
please refer this guide :
https://www.cisco.com/c/dam/en/us/products/collateral/switches/catalyst-9000/nb-06-cat-9k-stack-wp-cte-en.pdf
BB
Okay, regarding this document, we have to use Supervisor ports for the dual active link, too.
Thanks for sharing th Link
And you need extra license to use stackwise virtual if its not sup 1 XL?
Hi, yes that´s true. We switched to the XL Sup, so it is not neccessary for us anymore.
But thanks for the hint.
How to check the Upgrade license if running on SUP1 engine? bin file?
9400-PROD#sh ver
Cisco IOS XE Software, Version 16.09.02
Cisco IOS Software [Fuji], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 16.9.2, RELEASE SOFTWARE (fc4)
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-advantage Smart License network-advantage
None Subscription Smart License None
post the output of 'show lic'.
I think you need Network Advantage, which seems to be the one you have currently installed...so you should be fine. Check if the global command ' stackwise-virtual' is available...
kamallohiaji
Level 2
Level 2
Hi team,
Can we use 1G Copper for Dual-Active Detection link?.We have  C9500-16X-E Switches running with S9500UK9-169?
