Cannot clear ARP entry
lquin1978
We have two Cisco 1841 routers connected to one another (via a 2950 switch) Router A is 192.168.3.4/24 and Router B is 192.168.3.8/24.  Connectivity between the two is fine.. my question is when I clear the ARP on one of the routers, it automatically re-learns the MAC address for the other router.. I cannot get rid of it from the ARP table.. and im curious why??. I would have thought this information would have only repopulated once I generated traffic destined to the IP?
7 Replies 7
daniel.dib
Level 11
Level 11
Clear arp on Cisco platforms does not really clear the table. What happens is that the router sends out requests for the hosts in the ARP table. This is mentioned by Elly in this thread:
https://supportforums.cisco.com/thread/160214
This can be seen as below as well. I setup 3 routers in a subnet and pinged to learn the ARP. Then I clear the ARP cache:
R1#sh arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.0.0.1                -   c200.2094.0000  ARPA   FastEthernet0/0
Internet  10.0.0.2                0   c201.2094.0000  ARPA   FastEthernet0/0
Internet  10.0.0.3                0   c202.2094.0000  ARPA   FastEthernet0/0
R1#debug arp
ARP packet debugging is on
R1#clear arp-cache
R1#
ARP: flushing ARP entries for all interfaces
IP ARP: sent rep src 10.0.0.1 c200.2094.0000,
dst 10.0.0.1 ffff.ffff.ffff FastEthernet0/0
IP ARP: sent req src 10.0.0.1 c200.2094.0000,
dst 10.0.0.2 c201.2094.0000 FastEthernet0/0
dst 10.0.0.3 c202.2094.0000 FastEthernet0/0
IP ARP: rcvd rep src 10.0.0.3 c202.2094.0000, dst 10.0.0.1 FastEthernet0/0
IP ARP: rcvd rep src 10.0.0.2 c201.2094.0000, dst 10.0.0.1 FastEthernet0/0
You can see that gratitous ARP was sent first and then ARP requests unicasted to the current entries that were stored in the ARP cache. If we clear just one then ARP request is only sent to that address:
R1#clear arp 10.0.0.2
R1#
Why does it work like this? I can't be 100% sure but it's probably related to CEF, the information is needed for rewrite so it should be stored whenever available.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Please rate helpful posts.
Perhaps we have an issue of semantics, but I wonder about your statement that Cisco "does not really clear the table.". Your test shows very clearly that Cisco is clearing out all the dynamic entries in the arp cache
R1#clear arp-cache
R1#
and then Cisco immediately attempts to relearn the entries that had been in the table.
If your interpretation of "clear the table" is that it should result in an empty table then we can agree that this does not happen. But my interpretation of "clear the table" is to remove all of the existing entries, and Cisco does do that. The importance of this is that if some devices have gone out of service then their arp entries will not be relearned. But for devices which are still active in the network the Cisco router is ready to forward traffic to them as it is received. If it did create an empty table then it would not be able to forward a packet to a host until its arp entry was learned since if the router does not have a MAC address to put into the destination MAC address field it can not forward the packet and will have to drop it.
Rick
Yeah, what I meant to say is that people expect the cache to be empty after clearing it and that it will populate itself when traffic is sent. However the way Cisco implemented it is to refresh the entries.
The only way of totally clearing it is to shutdown the interface I believe.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Yes I agree. I have had similar discussions with people before who get confused because the show arp after the clear command looks so similar to the content of show arp before the clear. So they tend to think that Cisco did not do anything. But your test was very clear in showing that the existing entries are flushed and then are learned over again.
Some people do expect the arp table to be empty after clearing. And that would make sense for a host in the network. But if you think about how a router works it is not able to forward traffic until it has an entry in its arp table for the destination. So it would degrade service on the network if the router had to learn the entries one at a time as traffic arrives.
Yes the only way to prevent the router from re-learning arp entries is to shut down the interface. (and if you shut down the interface then you do not need the clear command)
Rick
Rick
You can also use the command "clear ip arp" which clears the arp table without sending the gracious arp messages. You will see this has more effect as it takes longer to re-learn the arp entries.
That's just Cisco's oh-so-helpful BROKEN behavior. "clear" should remove it from the table, not "revalidate" what's there. If it did, in fact, flush the table, then there would be nothing for the subsequent steps to unicast ARP. Your argument of degrading service is as incorrect as it is lame. If that host is no longer sending/receiving traffic, there's no need for it to stay in the cache. Yet, there's no way to remove it, and IOS will revalidate it every time it expires. This means the arp-cache can grow without bounds. And that's a problem for large broadcast domains like a cablemodem. (or anywhere proxy-arp exists.) One should not have to reboot the *** **** router to clear dynamic entries. (or find yourself a path to the "right" side to be able to shut/no shut the interface(s))
[For the record, I've seen CPE routers with over 10,000 entries in the cache, because they never expire and they can't be "clear"ed.]
Ed Roche
Level 4
Level 4
Hi folks....I ran into a similar issue with a certain type of printer (printer ATM cards) where the ARP entry will not clear. We turn the printer off, shut the interface, and the entry just won't go away. So I did a clear ip arp <IP> and clear arp. The entry stays and the Age doesn't go back to 0 like the rest of the entries. The only way to get it to change is to create a new static arp entry for the new printer. So my question is will the clear arp-cache the better option in this instance?
Thanks in Advance
