Cannot pass Vlan traffic between 2960x and SG300
b.tahmasebi
I have 2 switches 2960x and 2 SG300-28
I create vtp between my 2960 and every things is okay... And in SG300 create manually vlans exactly like name and ID in 2960 and enable GRVP in SG300, but cannot pass traffic between them, my uplinks are Trunk,
I have pinged in vlan 28 in 2960 switches
And I have like this vlan 28 in SG300, but I cannot ping my host in other side(in SG300)...
I set IP on every switch (vlan1)...
2960-01 > 192.168.2.230
2960-02 > 192.168.2.231
SG300-01 > 192.168.2.232
SG300-02 > 192.168.2.233
And I don't have any restricting on switch...
I reset factory all my switch... And I set just ssh and vtp and vlans...
I'm confused... I did this one time and worked good, but when I reset factory and configured again, but work not at all...
9 Replies 9
Borgenstrand
on 2960x switches, can you write switchport nonegotiate on the trunk ports? It could be DTP causing the issue. The interfaces on SG300, are they hardcoded to be trunks?
Dear Friend,
I did that (switchport nonegotiate) on every uplinks, can you explain about hardcoded in SG300...?
Hi, sorry, i was not clear enough. Hardcoded I meant manually, DTP in Cisco switches can cause them to think that a trunk port should be an access port hence, making them into access ports even though it is connected to another switch and should be an trunk port.
Now that you have done nonegotiate, is it still not forming trunks?
Dear Borgen this info about my ports
2960-01
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: Off
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
2960-02
Voice VLAN: none
Protected: false
SG300
Added by: D-Default, S-Static, G-GVRP, R-Radius Assigned VLAN, T-Guest VLAN, V-Voice VLAN
Port : gi27
Port Mode: Trunk
Gvrp Status: enabled
Ingress Filtering: true
Acceptable Frame Type: admitAll
Ingress UnTagged VLAN ( NATIVE ): 1
Port is member in:
Vlan               Name               Egress rule     Added by
 1                  1                  Untagged          V
can you run show interface trunk on the 2960 switches?
Please run show cdp neighbor as well.
Now, I found my problem, I joined interface 27(uplink to 2960-01) on SG300 to vlan 28 and I can ping it , but just in 2960-01 can ping that vlan, but every 2 switch 2960 are vtp but in 2960-02 can not ping that host in sg300...!
sh cdp neig...
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
0cf5a4c72d87     Gig 1/0/25        145              S I   SG300-28P gi27
SW-Core-02.Perla Fas 0             161              S I   WS-C2960X Fas 0
SW-Core-02.Perla Gig 1/0/28        136              S I   WS-C2960X Gig 1/0/28
b07d47830abc     Gig 1/0/26        144             R S I  SG300-28P gi27
Total cdp entries displayed : 4
2960-01
Port        Mode             Encapsulation  Status        Native vlan
Gi1/0/25    on               802.1q         trunking      1
Gi1/0/26    on               802.1q         trunking      1
Gi1/0/28    on               802.1q         trunking      1
Port        Vlans allowed on trunk
Gi1/0/25    1-4094
Gi1/0/26    1-4094
Gi1/0/28    1-4094
Port        Vlans allowed and active in management domain
Gi1/0/25    1,28
Gi1/0/26    1,28
Gi1/0/28    1,28
Port        Vlans in spanning tree forwarding state and not pruned
Gi1/0/25    1,28
Gi1/0/26    1,28
Gi1/0/28    1,28
2960-02
Gi1/0/28    1-4094
Gi1/0/28    1,28
Gi1/0/28    1,28
VTP Server on 2960-01
VTP Version capable             : 1 to 3
VTP version running             : 2
VTP Domain Name                 : Perla
VTP Pruning Mode                : Enabled
VTP Traps Generation            : Disabled
Device ID                       : 0c11.67c0.6680
Configuration last modified by 192.168.2.230 at 5-16-16 08:12:44
Local updater ID is 192.168.2.230 on interface Vl1 (lowest numbered VLAN interface found)
Feature VLAN:
VTP Operating Mode                : Server
Maximum VLANs supported locally   : 1005
Number of existing VLANs          : 6
Configuration Revision            : 3
MD5 digest                        : 0xAF 0xB1 0x4E 0x87 0x08 0xCD 0xE1 0x6C
                                    0x43 0xAF 0x95 0x26 0x9E 0x7F 0x7B 0xE3
VTP client on 2960-02
Device ID                       : 80e8.6f09.0e00
Feature VLAN:
VTP Operating Mode                : Client
Can you disable VTP Pruning? I wonder if that causes the issues, I do not think that SG300 can handle VTP.
Is it only Vlan 1 and 28 you are using?
Hi... I reset factory and set again... every things works good...
Thank You for your Help...
You are welcome, very good it works for you now.
Please rate and close this thread :)
