Cannot upgrade firmware for EHWIC-4G-LTE-A on 2901ISR
Joshua Smick
I've been trying to update the firmware on my EHWIC-4G-LTE-A with no luck.  I've been following the instructions found at http://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/NIM/software/configuration/guide/4GLTENIM_SW.html#88572, and no matter what I do, it fails:
Tardis#microcode reload cellular 0 1 modem-provision flash0:MC7700_03.05.29.02_00_generic_000.000_001.cwe
Reload microcode? [confirm]
Log status of firmware download in router flash?[confirm]
Firmware download status will be logged in flash0:fwlogfile
Microcode Reload Process launched for hwic slot=1; hw type=0x721
Tardis#
 Modem will be upgraded!
 Upgrade process will take up to 15 minutes. During
 this time the modem will be unusable.
 Please do not remove power or reload the router during
 the upgrade process.
F/W Upgrade: failed: can not locate F/W file
It's on the flash:
Tardis# dir flash0: | inc MC7700_03.05.29.02_00_generic_000.000_001.cwe
   49  -rw-    38245604   Feb 3 2017 03:12:22 -05:00  MC7700_03.05.29.02_00_generic_000.000_001.cwe
What might I be doing wrong?
6 Replies 6
for the upgrade to work, you need to also download the PRI .nvu file that is listed together with the .cwe file on cisco's download page. Then, create a folder on flash or bootflash of your router and run the microcode command using the folder instead of the .cwe file only. e.g for my case i downloaded both files:
7430_02.20.03.00_Generic_002.017_001.nvu
74XX_02.20.03.00.cwe
and then put them into a folder on the bootflash, called 4G_Fireware_pkg and then run the following command: microcode reload cellular 0 1 modem-provision bootflash:4G_Firmware_pkg
hope this helps
I am trying to find both files to download. But I do not have good luck finding one. can anyone send a link where I can download?
DM me if you need more help... I flash a few of these a year and have probably done 20 or 30 total in my career.
brett.stone
I had the same issue and after week of trying various things, I finally found a solution.  First, the MC7700 modem by Sierra will only work up to Cisco 15.5 and will not work on any firmware above 15.5.  If you are using an IOS above 15.5, downgrade to 15.5 and then apply the firmware upgrade on the ewhic using the microcode reload command.  Sometimes you need to flash the ehwic up to 5 or 6 times before it will accept the flash.
Thanks. I have a 1941W running 15.8 and bought an LTE card but as soon as it booted up the router was constantly complaining about the modem being the wrong SKU and rebooting it every 10 minutes. It wouldn't upgrade or if it was about to, the cellular just reloaded. Got 15.5.3 and it seems to be fine now.
