Catalyst 3550 Series; L2 or L3?
insccisco
Hi guys,
I'm not too sure but I have a 48-port Catalyst 3550 Series switch and I need to know if this switch is a Layer 3 switch?
When I do a sh ver, one of the things it says is "Running Layer2/3 Switching Image"
thanks in advance
16 Replies 16
srue
Level 7
Level 7
yes, it's a layer 3 switch. by default though, routing is not enabled.
you can turn it on with the 'ip routing' command. also, there are two different image versions, standard and enhanced. both do routing.
more info here:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps646/prod_qas09186a00800913d3.html
I was just reading that. So by enable the "ip routing" I will be basically enabling routing within this switch?
I want to make sure because I will be putting 10 networks in this switch and once I VLAN each of these networks, I want this 3550 to be the default gateway in each of those VLANs.
Let me know if I will be able to accomplish this with this switch?
thanks
Yes you can do this. The 3550 will route between the vlans because they are directly connected.
Jon
Yes you will be able to accomplish that with your switch. Just create your interface vlans, enable ip routing as the above poster said and then assign your ports to the correct access vlan id. Here is a basic link on the 3550 administration guide.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_19_ea1/configuration/guide/swiprout.html
good, so I will just setup each VLAN, give them their IP address and then use this IP as the default gateway for all hosts which will belong to those vlans, right?
ap
That's correct.
you're the greatest.... thank you for the confirmation... I always try to be 300% sure when dealing with cisco as it is quite a big area
I will go ahead and deploy this 3550 switch with all the inter-vlan routing. This is good news as it will free up like 6 physical interfaces that I was using out of my router in order to have routing from all my vlans in 2 2950 switches.
thanks a lot
According to my knowledge, usually a 3550 comes in the 'core' layer of the three layer designing model (access layer, distribution layer & core layer) that Cisco describes.
In that it normally says that you fix 2950 switches at Access layer, because it is to access layer that the users connect to.
Then at distribution layer you fix the routers, where inter branch and inter VLAN communication happens at this layer.
Then finally it says at core layer you fix a multi layer (layer 3) switch. The core layer connects to the backbone. A packet goes to the core layer means that it has to go out of the network to the public network.
My question is, if we use a 3550 at the core layer as a L3 switch, how can we connect a leased line or any other WAN connection, I mean to which ports of the switch can we connect them to?
Thanks in advance!
Omal
If you think of WAN in terms of leased line then the 3550 does not have an interface that connects to leased line. In that case perhaps the 3550 as the core switch is doing inter vlan routing and could be connected to some router for WAN routing.
And in many networks these days a WAN connection may come on an Ethernet interface, such as DSL or cable modem connections or Metro Ethernet connections. In that case the 3550 could provide connectivity to the WAN without needing any other device.
Rick
Rick
Hi Rick
Thanks a lot for your post. It helps a lot.
I just have one more question. In a 3550 switch that I have, I get 24 Rj45 ports and two some big slots. What are they please?
Thanks in advance!
Omal
The two big slots are for GBIC (GigaBit Interface Converter). The GBIC provides flexibility to use copper, fiber, or the GigaStack converters to establish connections.
Rick
Rick
Thanks Rick. Thanks a lot for your information. It helps a lot.
Take care!!
hey Rick, these GBIC slots are there to link up the switch with another one to make it seem like it is a one unit? right?
You can use them to interconnect your 3550 switches but they do not appear as one device in the same way that the 3750's appear as one unit.
Edit - apologies i may not have explained that very well. You can cluster 3550 switches to be managed by a single IP address. I just wanted to stress that it is an older technology than the 3750's. For 3550 clustering info see:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.2_44_se/configuration/guide/swclus.html
Jon
