Catalyst 3560 V2
davidm
Community Member
So, We've just received two new catalyst 3560V2 switches and either I've lost my mind or the IOS has had some changes...
Line VTY 0 4
     Login Local
command does not work.  So, I downloaded a new IOS
c3560-ipservicesk9-tar.150-1.SE2
and still no luck...
Have I lost it or does the IOS no longer support it?
Here is currect Console and VTY lines running on a different 3560 switch...
line con 0
privilege level 15
password 7 152B29025438262524
login local
line vty 0 4
access-class 99 in
privilege level 15
login local
line vty 5 15
access-class 99 in
privilege level 15
password 7 012A240A0B190B0E2D
login local
siddhartham
Level 9
Level 9
its most likely the aaa new-model config
Siddhartha
sachinraja
Level 11
Level 11
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/15.0_1_se/configuration/guide/swauthen.html#wp1046352
The config guide does give "login local" as a supported command.. what do you see after going to line vty 0 4 ? can you give a  ? after login to see the options ?
Nandan Mathure
Level 7
Level 7
Do you have "aaa new-model" configured? that might be causing it or check if local username password needs to be created first etc.
Nandan Mathure
siddhartham
Level 9
Level 9
Siddhartha
