Catalyst 3650 stack issue
Rohit Mangotra
Level 3
Level 3
I am trying to stack 2 3650 switch with same IOS both of them are L2 LAN based switches. When I connect the two switches I get the error mentioned below.
Bootable image at @ ram:0x5342f388
Bootable image segment 0 address range [0x81100000, 0x81b8adc0] is in range [0x80180000, 0x90000000].
@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@boot_system: 377
Loading Linux kernel with entry point 0x816903a0 ...
Bootloader: Done loading app on core_mask: 0xf
### Launching Linux Kernel (flags = 0x5)
Final tar file: mcu_ucode_bundle_8_1_0.tar
*** Stack adapter authentication failed on stack port 1 on switch 2 ***
Stack Adapter Auth Fail : SIF_SERDES_CABLE_EASTBOUND
Waiting for 120 seconds for other switches to boot
All switches in the stack have been discovered. Accelerating discovery
Chassis 2 reloading, reason - active removed before switch became ready
Apr 4 10:49:44.008 R0/0: %PMAN-5-EXITACTION: Process manager is exiting: reload fp action requested
Apr 4 10:49:52.640 R0/0: %PMAN-5-EXITACTION: Process manager is exiting: rp processes exit with reload switch code
octeon_wdt: WDT device closed unexpectedly. WDT will not stop!
reboot: Restarting system
Switch#sh switch
Switch/Stack Mac Address : 58f3.9cac.0f80 - Local Mac Address
Mac persistency wait time: Indefinite
H/W Current
Switch# Role Mac Address Priority Version State
1 Member 0000.0000.0000 0 V04 Removed
*2 Active 58f3.9cac.0f80 1 V01 Ready
Have anyone seen this issue before. Anything I can do to fix this issue?
Thanks in advance
Kind Regards
Rohit.
16 Replies 16
Leo Laohoo
What firmware is the stack running on?
CSCvo12056
Hi Leo,
This is the software version I am using in all the switches. I am having the issue when I am using 2 Catalyst 3650 switches 48 ports or one 48 ports and other 24 ports.
Cisco IOS Software [Denali], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9- M),
Version 16.3.7, RELEASE SOFTWARE (fc4)
Thanks & Regards
Rohit.
Deepak Kumar
What is the firmware version? We noticed the same type of bug in C9300 switches.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Deepak,
I think you're hitting this:  CSCvn30950
Hi Deepak,
Thanks & Regards
Rohit.
Let please confirm a few things:
1. What is happening if you are booting the same switch as standalone?
2. Are both switches are having same IOS version?
Deepak Kumar,
Hi Deepak,
When we reboot the switch independeltly the stack configuration is still there and after reboot it still have got the same. So I have to hard reset the switch to factory default. If they work standalone they work fine.
Yes both the switches have got the same IOS version.
Thanks & Regards
Rohit.
Hello
Just like to add and confirm how are you stacking these two switches?
Have you provisioned the master switch prior to stacking it -
Do you shutdown the slave switch prior to attaching it to the master?
Have you made sure the stack cable cables are okay and are seated correctly
Kind Regards
Paul
Hi Paul,
Yes I had provisioned the master switch prior to stacking it.
Yes I shutdown the salve before I connected it to the master switch.
The stack cables are brand new.
I did stacking for three 3650 48 port LAN based and it went just fine. No issues. I am only experiencing problem with the same model switched that I need to deploy in different location. Not sure what's going on.
Thanks & Regards
Rohit.
Did anyone find a fix to this?  I'm deploying a bunch of 3650s and am running into the same issue.  I'm running 16.3(8) on all stacks.  4 stacks are OK and 3 are showing the following error:
*** Stack adapter authentication failed on stack port 1 on switch 1 ***
Jul 10 15:20:07.377 R0/0: %PMAN-3-PROCHOLDDOWN: The process sif_mgr has been helddown (rc 134)
Jul 10 15:20:07.952 R0/0: %PMAN-0-PROCFAILCRIT: A critical process sif_mgr has failed (rc 134)
Jul 10 15:20:08.456 R0/0: %PMAN-3-RELOAD_RP: Reloading: Switch will be reloaded
Chassis 0 reloading, reason - Non participant detected
Jul 10 15:20:17.840 R0/0: %PMAN-5-EXITACTION: Process manager is exiting: reload fp action requested
Jul 10 15:20:28.268 R0/0: %PMAN-5-EXITACTION: Process manager is exiting: rp processes exit with reload sw itch code
Jul 10 15:20:47.050 R0/0: %PMAN-3-PROCESS_NOTIFICATION: System report /crashinfo/system-report_local_20190 710-152041-Universal.tar.gz (size: 5621 KB) generated
The switches are just rebooting over and over.  If I remove the stack adapters they come up in standalone mode just fine.  Then when I re-insert the stack adapters and reboot they get stuck in a boot loop again.
What is going on here?  Does anyone have a fix for this?
Update the firmware to, like, 16.6.6.
I thought 16.3(8) was just as new as 16.6(6).  Do you know for sure if this bug has been fixed in the 16.6 train (where it hasn't been in 16.3?).
I only ask because I'm pretty sure some of my switches came running 16.6(6) and still didn't boot properly with the stack modules installed but I'm certainly happy to try upgrading.  I will post my results as soon as I can.
Upgrading from 16.3(8) to 16.6(6) did not fix the issue.  What else can I try?
Jul 12 16:52:05.819 RP0/0: %PMAN-3-PROCHOLDDOWN: The process sif_mgr has been helddown (rc 134)
Jul 12 16:52:06.025 RP0/0: %PMAN-0-PROCFAILCRIT: A critical process sif_mgr has failed (rc 134)
Jul 12 16:52:06.257 RP0/0: %PMAN-3-RELOAD_RP: Reloading: Switch will be reloaded
Jul 12 16:52:14.650 FP0/0: %PMAN-5-EXITACTION: Process manager is exiting: reload fp action requested
Jul 12 16:52:19.048 RP0/0: %PMAN-5-EXITACTION: Process manager is exiting: rp procesJul 12 16:52:51.101 RP0/0: %PMAN-3-PROCESS_NOTIFICATION: System report /crashinfo/system-report_local_20190712-165244-Universal.tar.gz (size: 7426 KB) generated
Raise a TAC Case. This could be CSCvn96821.
