05-23-2021 07:50 PM - edited 05-23-2021 07:59 PM
I have a Catalyst 3750-E with 2x Twingig Converter Module (CVR-X2 SFP V02) installed:
Is this compatible with Cisco 10Gb/s SFP+ Twinax Cable, 10G DAC Direct Attach Copper Cables?
Link that I bought them from: https://www.ebay.com/itm/203179408042?var=503671271624
Also, is this a true 10G Twingig module? Or does it operate at 1000mb/s? Does the module provide 10gps?
Thanks you
05-23-2021 08:00 PM
No, CVR-X2 SFP V02 converts one 10Gig to 2 1Gigs. The 10G DAC Direct Attach Copper Cables are straight 10Gig with SFP+.
In another word, the switch is one gig and the DAC is 10Gig.
05-23-2021 11:51 PM
Last i have tried did not work for me, it works on new Cat 9K
